View Full Version : C3 General
- 70 A/C oil, how much?
- 1973 Corvette
- Willcox Weekend Sale Wiring, Stock Frt/RR Suspension, Seat Covers, Carpet
- door weather stripping
- Check out this "beauty"
- Fire extinguisher reprise
- Need Help w/ SB Water Pump Casting Number
- 1969 stock rims... Widest "meatiest" tires
- door hardware paint question
- Vettes4vets
- Lose Yourself in This 1971 Corvette LT1's Timeless Beauty
- What would you pay for a 1977 c3 with 100k miles?
- Storage compartments
- '69 Driver Side Vent Cable
- Classic Car Restoration Club email
- Marker bulbs
- Dome light behaving funny
- 1971 small block valve cover bolts L & A
- Key fobs?
- Introducing RideCache - with special offer for CorvetteForum members
- did c3's ever come with a overdrive stick shift?
- Rear differential codes?
- Willcox Week Long Sale starts now and ends Friday
- tire age
- Tach wiring question
- Turn Signals Went Inop Yesterday
- ignition switch light?
- Tires
- Another 76 steering wheel question
- 70' Coolant Over-Flow Tank?
- Carpet adhesive
- Door Vapor Barrier Sealant?
- My 1968 Blown 383
- Power steering pump fix
- 71 LS6 on ebay
- Advice on buying a 1976 C3
- Headlight & Wiper Door Vacuum Cowl Steel Tube
- Help needed!
- Mecum -Kissimmee 2016
- ,69 Dash Vent Ball
- My 1977 Restoration project
- Power steering issues
- New to Me C3 Race Car dash Question
- Question: frame back on body?
- Fender Skirt Q - Recent C3 Acquisition
- Are all window regulators created equal???
- new wheels and tires
- Paint chipping in door jam on a 71
- New extinguisher mount finished
- Tires For a '71
- NCRS Michigan Chapter visits DeWitts
- Hate to ask, but what's a fair offer?
- What is this in the top of the rear wheel wells
- What to do with this stuff...
- C3 T-Stat observation & ?...
- Oil FIlter recommendation
- BDoc...Does anyone know forum member BDoc?
- Speedo cable under dash routing for 4 speed Manual
- My Wedding day with my C3
- Let There Be Light,,,,Cluster LED LightS!!
- Willcox New 20 off sale Starts now!
- C3 sound bar?
- Wich horn button on later c3 steering wheel
- Does this mean the valve stem seals have already been replaced?
- Facebook Fridays: Minnesota Man Builds Corvette Out of Snow
- ZZ4 Air Conditioning Bracket
- Will these fit a small block....?
- C3 79 battery drain
- Interior bezels and trim help
- Have a few questions on parts and techniques
- 530planeman Son Coming Home I thank all of you
- Air Cleaner ID
- LT-1 engine cost
- Looking to buy my first 1980 C3, a little help?
- Bleeding brakes
- should i pull the trigger on this one... part 2
- 41 years old today
- Eastwood paint question
- Fuel tank sending unit
- Check the cheap stuff first
- A 1982 Corvette brought back from the dead.
- Crossfire air cleaner
- 79 mystery part identification
- Where to Purchase 71 LT-1 carb/intake gasket??
- Gymkhana suspension?
- 68 rear defogger mission
- My AMAZING visit to Auto Gear (AGE) in Syracuse today
- Brake pad question
- Orange County, CA Painter Needed
- Patiently waiting for spring
- FI Conversion reccs?
- Headlight beam switch
- Willcox Weekend Sale Starts Now, Ends Sunday.
- Best Way to Repair 2 Holes in Frame
- Identify Part
- Lock cylinder install
- Repro Radio for the 70
- ~~ St Jude Auction #2 ** APPLE WATCH 38MM S GRY AL BLK SPORT-USA ~~~
- 1971 Corvette Coupe
- Climate control lever question
- telescopic lock screws
- Turn signals
- Rebuilt wiper switch
- Gorgeous '69 L88 Corvette Convertible Heads To Auction
- Gas Monkey Got the Wrong Corvette Summer Car
- What is this small indention under my passenger seat?
- Radio push button questions
- anyone use these jack stands?
- Turn Signal Short
- door adjar switch
- seat cover install
- Repair old clock
- Factory A/C
- Chrome Radiator Support Cover
- Got Me Some Bitchin Rims!!
- Willcox Week Long Sale Weatherstripping, Door Panels, Carpet , Wire Harness!
- 1971 vette id
- My 1974 454 Convertible at Mecum Kissimmee
- How to fix outside window rims on C3
- Recommendation for new clutch 1970 454
- Interesting "Barn Find" in Ohio
- Info on the Hot Springs Corvette Weekend
- My C3's bedroom just got a lot nicer...
- Here is a interesting video about C2 and C3 brakes
- Idler pulley
- New power window switches finished
- Is there a correct orientation for differential cross Members?
- Wiring harness surgery
- '79 L82 tachometer mystery indicator
- Front speaker suggestion
- Instrument panel picture 1968
- Battery Issues
- Snowflake style corvette wheels
- No heater
- NCRS Winter Regional Show Lakeland
- So what do you guys think this will sell for at BJ????
- What size tire/wheel are you using on your c3?
- Transmission cooler lines
- Take off T tops
- Optional wiring?
- corvette Central Fiberglass
- New parking brake handle finished
- repair comfort weave foam on original seat covers
- Would a Powerball win change your C3 plans?
- 1977 Corvette Owners manual
- 71 Power Antenna
- 1979 Blown Fuse
- How to Remove The Crankshaft Pulley??
- Early 68 cluster convertible interior parts quest
- Metal Device bought from an old Corvette Shop
- Anybody know what it is?
- Free Corvette
- 1969 side pipe covers, where to get best price?
- Manta Ray center caps???
- Red73
- rear tires
- Trying to understand spare tire rim cosmetics for judging purposes one day...
- Watch 6 Generations of Corvettes undergo Wind Tunnel Testing
- How do you remove the radiator without tearing the seals?
- Removeable Cross Member Change???
- is the 1 1/8 front sway bar worth anything?
- Corvette shop in Portland Or.
- emblem paint
- New shocks installed, and it went surprisingly well!
- (( What year corvette))
- front light problem
- Fire Extinguishers - Which kind is best?
- Save 10% on Green Air Filters thru Jan 11
- Knee replacement
- vin number help
- 1968 Telescopic Steering Column Repair
- Nashville Speed Shop
- Sold my 82 CE
- New C3 Owner
- A pillar weather strip retainer
- Corvette Hardtop Inquiry
- 1973 with ZZ4 intake, stock Roch and air cleaner??
- 1973 air cleaner
- anyone have a desktop dyno im wondering how much power my 350 has
- Rocker panels
- 1973 C3 With A Non-GM Motor
- CL '73 auto yellow for 7500 not mine
- seperate frame and body without lift and rafters
- 1974 454 convertible coil spring replacement
- Looking for forum member Michel B
- Cheap 454s
- Willcox New Weekend Sale Starts Now, ends Sunday!
- Garage Heater Location
- Arizona c3 folks
- help with center caps
- Ouch...
- 70 convertible 454 question
- Rivets
- 1971 Convertible... "Back in the day"
- 79 Virgin
- NJ - Help me find my fathers 1974 Corvette
- Console Plate Restoration questions
- Screw removal problem
- How do I remove the headlight knob?
- 72 base coupe value?
- VIR rebuild
- Hardtop headliner
- 77 corvette parasitic drain.
- bigger a/c blower
- 1975 Tach Stuck at 1,900 RPM
- Dewitt's Radiator
- ? for the Forum Members..
- Lifting Body off frame from underneath
- Replacing my 80 gas tank
- New Paint to cover vandalism! Sweet!
- Who restores original shocks
- Items found in body bolt cavity??
- Need to learn a little about rear hardtop studs
- will it fit ?
- 355 sb or 396 bb?
- 1982 Corvette nose misaligned. Anyone ever attempt a realignment/repair?
- Maxx Power Tri Flow 28" Aluminum Radiator ?
- 72 vs 73 pillar posts
- Cast Your Vote for Car of the Month for December
- sunday drive
- Steering Column Paint
- Mater cylinder help
- HardTop question?
- Spring inside lower radiator hose
- What Are Some Really Good C3 Summer Cruising Tunes?
- New York Resto Mod?
- 1972 corvette magazine ads....?
- wire ID please
- Alarm on 74
- Original Interior carpet source
- Power Steering Cylinder: Rebuild, New or Rebuilt, what works?
- Speedometer in KPH instead of MPH?
- C3 lower rear shock mount install.
- Decals And Brake Fluid
- GM parts catalog
- California Stingrays & The Mother Lode Corvettes Summer BBQ
- 82 mph tach gauge removal
- Stolen - not forgotten - recovered
- '81 OEM Exhaust Parts
- Replacement Bloomington Gold Cert
- good car tunes from the 90's till now?
- removing rear leafs?
- No taillights
- 82 Fuse Bos Connector
- 1982 C3 Overdrive electrical question.
- Check in here if you're staying home tonite
- 1980 Project, Worth it?
- Oil pressure, what's normal ?
- Is this repairable?
