- Floor Mats: Dr or Pass side??
- Early 78 with ZX2 but non-intermittant
- 69 horn button assembly
- Thread bumping - Apologies
- DeWitts Flash Sale!
- Suggestions please, driver armrest
- Preferred Parts Supplier for C3
- Door mirror
- Insurance
- C3 L71 available w/auto trans?
- Exhaust hanger problem
- 69 Front Grill/Fiber Optic Connection
- 1973 454 idenifying orig block
- 73 corvette pictures
- Need a steering wheel cover for a 77
- 71 Coupe Restomod
- Oil Pan Gasket
- Car cover recommendation
- Wave The Flag and Take Pride in Your Ride!
- Looking for help from Alignment Gurus
- My new HW C3 corvettes
- Engine ID on a '77
- Best body shop for birdcage repair in southeast
- need help 69 350/350 with pb option
- 1981 Tail Light Housings
- Great deal at Ecklers for the 1982 CE Full decal kit
- Hot water shut off vacuum valve (switch)
- I've been looking at this '72 Coupe and I don't know whether I should buy.
- Windshield frame black-out?
- Drivers window adjustment
- Fuse box
- 1981 No Rear Brakes
- Quadrajet Carb Help
- What do to with old cam
- Crank/no start condition
- GM power antenna
- C3 steering ratios(?)
- Quest for First C3
- crushed
- Any know a website for car faxing C3’s I cant find one that except 13 digit vins
- Lucas Oil Products
- Solution for Running Aftermarket Wheel on Tilt/Telescopic Steering Column?
- 1978 Rochester: is this a vacuum diaphragm device?
- Help me decode my 1971 Convertible build sheet
- How lucky can a guy get?
- Vacuum
- Window alignment in San Francisco area
- 79 Seat hinge is broken
- fan clutch replacement
- 1969 Corvette News complete Subscrition Card
- Happy Birthday
- Another OEM radio question
- Testing the OEM heat sink/convector
- Auto Body Shop in Freehold NJ
- Best Primer
- 74 vette trim 400 80l paint
- 1969 427 "MK" Production
- crossmember dent removal tool
- California carb/exhaust
- First Wash in 45 Years: BARN FIND Corvette With 1599 Original Miles! - Youtube Link
- Paint stripping question
- 1956-1976 C3 Corvette Oil Pump Standard
- 1970 L46 heads
- L46 man
- 72 454 4 spd no crank no power.
- Nardo/Destroyer Grey Paint Job?
- Beautiful Stainless Steel Fittings
- Insight on restomod/modern wheels?
- Early 68 coupe rocker molding exterior question
- C3 randomly wont start - no starter sounds
- Smog Pump
- Trim Parts Rear Tail Lens FYI
- Alternative to Vega Steering Wheel
- 69 Parking Brake Pully Bracket Destroyed
- Paint/Primer question
- Wiper Door and Vent Question
- A BIG Thank you to Original GM Hardware
- Doug's SS Sidepipe Headers WithvSteeroids
- Foot wells and pedals - more room?
- Antenna
- Wiring diagram
- 81 C3 Door Handel Modification
- 1981 C3 Door Lock Tumblers
- 454 block huggers are being a pain!!!
- red line tires
- Stub Antenna or cover
- L-48 or not?
- DeWitts Tax Sale
- Broken side mirror base screws in door
- c3 rebuild
- Windshield Wiper Connector Reversed
- Which oil pump for stock 1969 350/350?
- 76 Greenwood Vette Hot Wheels
- Why Can't Find Luggage Rack?
- 70-72 Front Bumper Guards
- Van Steel Corvette Contests
- Help with ID of parts
- 1971 Warbonnet Yellow Vert LT1 SEEKING HISTORY?
- Those that installed Energy Suspension bushings in your Trailing Arms...a question
- Anyone in Des moines IA that could pick up a spare tire for me and ship it?
- Changed a fuse, what could possibly go wrong?
- What’s my engine?
- Headlight replacement - help with washer sprayer
- My car value...'72 vette vert...
- What price is worth it for a 1973 Chevrolet Corvette?
- new member here
- Advise on buying a corvette from 1978 with apparent rust
- Quadrajet: Original vs. Service Replacement
- 1980-1981 C3 Corvette Wheels Center Caps Package
- Title clarification
- Headlight Switch Grounds?
- Zinc parkerizing vs. zinc electroplating
- Fix / Replace 4 port client control valve
- One Stop Fastener Vendor
- Chrome plating in the southeast
- Balancer Bolt
- Fuel Delivery Problem
- Does anyone know what this piece is?
- Thermostat housing bolt stick
- Will NCRS tell you what a 68 came with
- Always wanted one..
- George Carter
- Transmission fluid leak
- What would it take to fix this? I thought the rear and front bumper
- Driveability- High Compression 454 LS5
- Temp Bypass Mech. Fuel Pump: how to
- Engine Bay Match Paint to body or Black?
- Choke coil year?
- 3d Scanning
- '73 windshield wiper/washer electrical cconnector
- Plug wire problem
- Brake light switch conversion from 68 to 69
- identify c3 seat tracks
- Original Leaf Spring Manufacturer
- Should I pull the trigger on this 75' ?
- Tach Question 1975
- 72 Intake Manifold question
- Classic car VIN check company (Fraud)
- C3 Bumper Conversion Mold
- Help w/Brake bracket ID year?
- Acronyms
- Taboo??? Trim tag rivet?
- Solar Sale
- inner window felt
- C3 Side Mirror Loose - teardrop portion
- 1970-1974 Corvette C3 Vinyl Seat Covers Black CA417820
- 1978-1981 Corvette C3 Gas Tank Kit - 25gal CA-52251
- Re-installing A/C after rebuild. Expensive?
- C3 Tires
- Carburetor Cleaner Fuel Additives
- OldGTO
- Looking for a certain, very low mileage Silver Anniversary car
- keep, sell or throw away
- Recommended Shops to Work on my C3?
- 1978-1981 Corvette C3 Dash Pad - Black & Red Color Options
- charging
- Wiper washer pump removal
- Looking for experienced corvette mechanic
- Worth fixing?? 1976
- Why don’t these wheels fit my ‘81?
- Header bar and headlight support bracket.
- Seat fitment
- Part purpose and name
- New to the boards, Just got my C3
- Center screen that displays gauge information?
- Rear compartment light bulb falls out
- C3 41009 15"x8" Rallye Wheel Set W/Replacement Hubcaps & Stainless Steel Trim Rings
- Body man sloppily filled holes what to do
- Tdc?
- Two Questions
- Any leads on Pre Purchase Inspection in New Jersey area?
- 68 wiper motor
- was the hood strip painted on the 1982 Collector Edition
- 1971 vette with different body kit
- Neil Young old photo
- REMINDER: Billy Boat Exhaust Spring Sale Event!
- Anyone in Hialeah?
- 81 fresh air vent
- Radio year ID?
- My 1978 corvette will not fire
- Got a new 1969 Coupe - question about distributor from previous owner
- Missing Door/Exterior Keys
- Will a Doug Nash 5 speed transmission:
- No rear lights
- What color black did you chose?
- 1980 cloth seat covers
- * h a p p y e a s t e r *
- Pics of your latest Roadtrip Forum members.....
- What is this wire
- Holly Brawler 650
- Crate 502 for my 1979
- 69 - gas pedal/throttle question
- What 1 year items will I find I need on a 68??
- Considering this 1979 C3 - Looking for this forums thoughts
- Shout out to Carburetor USA!
- 76 Rear Window Install
- Differential crossmember bushing replacements
- 81 automatic half shaft u joints
- What is this wire
- 1982 power mirror issues, need some help
- Help me identify 68 master cylinder
- Tabs on Flywheel Cover
- Need help identifying 327
- Early C3 sun visor repair/replacement?
- 1968 Rocker Channel Relacements
- Corvette Summer Build
- Shifter knob spring
- Shocks
- 73 Service Manual
- Best Youtube Channel & Parts Store for a '68 C3
- Corvette C3 speakers box
- Speaker Re-cone Source
- Radio Wiring to New Unit?
- Should I buy a C3-C4-C5?
- How Many 3 Speed Manuals Out There...
- Ashtray Door Fix?
- 79 L-48 Rookie rescue to cruiser- HELP will be Needed
- Looking for advice fixing rear end
- cooling fan temp sensor pigtail
- 69 bigblock hood fit a 1970 C3?
- 69 big block fit 1970 c3 corvette
- Main Fuse Size?
- Rare c3 tail lights
- Thoughts on this undercarriage?
- Leather Steering Wheel Re-Wrap
- Austin, TX Engine Builders
- help with alternator and starter wiring
- 76' Door Pillar Weather Stripping gap
- 81 C3 Exterior Progress
- A question for the lowered crowd
- Smoke at the alternator and starter area.
- April 28TH 18th Annual The Greatest Show of Glass VETTESTER CORVETTE SHOW 2024
- Assistance/Recommendation - Pre Purchase Inspection on C3 in Greensboro NC
- Is it worth the price? 1973 Chevrolet Corvette Stingray C3
- Riddle me this - what are these parts ?
- Help with tires/rims
- Carb quadrajet vs edelbrock
- Will a 1982 CE steering wheel horn button fit
- 1968-1969 Versus 1969-1972 Hood Identification!
- No running lights 0n 78 c3
- Block numbers
- “Dummy” question - Light?
- Front frame extensions
- 77 Pawn Shop Vette
- Birdcage and windshield frame rust
- Can anyone identify these parts?
- C3 headlight switch question.
