View Full Version : C6 Tech/Performance
- Squeeky Brake problem
- How to replace a side mirror?
- New Six Shooter shifter-NO CORE-
- Opinions Needed - Breathless PP C6 Shifter
- Thanks to the guys at breathless performance in south florida
- On Road Tuning
- 93 OCTANE in Nashville TN???
- X=Pel Clear "Bra" nose and headlight protection
- Question on Fast intake
- Rough Idle? or the Hickups
- Info on fast intake
- Whats the difference between a mustang dyno and the other type?
- Passenger Door Problem
- What should my Air/Fuel Ratio be? ...
- Callaway C16
- Koni sports ???
- Vararam
- !!!!A.R. Headers December Blowout Sale Before Price Increase!!!!
- pics of my N20 setup
- C5/C6 KONI FSDs
- Looking for a PCM Wiring Diagram
- If you had to choose one!
- Got the headders put on today...
- Random Technology Exhaust
- AFR 205 or CNC ported stock heads?
- Jet Hot Coated Kooks Long Tube Headers On Sale (C6 and Z06)!!!
- C6 Hatch Screws
- If you have westcoastcorvette lowering bolts installed plz respond!
- need tips on beefing up drivetrain..
- Tapping sound
- Help with lowering c6 with stock screws
- I've only experienced wheel hop once in my C6
- C6 GM Performance Exhausts
- Bitten by the Column Lock Monster......Help
- Oil Filter Wrench
- 2005 M6 Coupe Mod results
- Most Modified 2006+ A6 Vette
- oops
- 160 theromstat
- Lowering kits,Z06 tire combinations?
- Anyone ever hear of such a thing?
- Help me with my decision on MODs plz
- pls help: C6 Z51 brake questons for a DE event
- Would anybody purchase polished wheels?
- Seat bolsters will not inflate
- Black Motorsports Wheels- durability of painted finish?
- C6 Automatic Transmissions
- Z06 Clutch In A C6
- Stock rear end?
- Battery has a charge but car is dead
- Cold Air Mod
- Cam installation...need help!!!
- Polished wheel issues???
- What Is The Best Nitrious Set Up Out There
- Will front 01' Camaro SS wheels fit ?
- LS6 Intake on C6
- Any gains from ported throttle bodies?
- Different. . . diferential chatter additive
- Need stock HP/torque on 06
- Z06 Brakes on a Base C6
- Wich Pip is better to install
- ***"Cyber Monday" (and Tuesday) Sale!!!***
- Why Dyno #s can't be taken TOO SERIOUSLY
- New Vette Owner In N. Cal...Need Mod Help
- South Orange County (CA) dealership recommendations?
- Dead Battery
- Beating the system (emissions)
- WTB Grey comp wheels
- Buring oil smell
- Installed Headers Today
- Installing 160 Thermostat in C6--HELP!
- engine light on, after flashing comp. and procharger install??
- C6 top speed in each gear(MN6)?
- 1 3/4 or 1 7/8 LT headers
- Locked out of Park (A6)
- anyone else have the gas door constantly pop open????????
- GoodYear F1 Supercar EMT Vs PS2's ???
- *** L76 intake serious casting issues found - intake is JUNK
- Need help with aftermarket resonator, pics
- Haven't bought the car yet, but one step closer, Headers & Bullets
- Installed Callaway Honker...Awesome!!!
- Lower and Rubbing... C6?
- procharger chirp?
- Headers, Vert funky smell? Comments please
- The truth of B&B Bullit PRT's
- Diff. noise and chatter 4th time going back
- L92 416" Short Blocks @ SDPC
- Here are the pics of the cam difference between 06-07
- how does the C6 breath?
- c6 engine diaper?..
- How Accurate is the PASSPORT G-Timer GT2/GT1
- lingenfelter heads and cam install instructions
- c6 convertible roll bar available yet?
- Precision Red Good and Bad - After Market Add Ons
- WTB/Find 17in +79mm offset for rear d.r.'s
- Question about AutoScanner U480
- Disconnecting seatbelt chime?
- A & A GP on DeWitts
- Clutch fluid
- baer rotors
- Which Rims and Tires for Track?
- From clutch problems to tranmission how's this happen?
- Decel with paddle shift
- Using front wheels for drag radials?
- Trans noise
- Is too much oil harmful
- High RPM burnout causing low ET's on stock cars??
- c6 oil pan
- shift from 2nd to 3rd not smooth
- New Clutch - New ET/MPH
- Hit reverse at 140mph last night...
- For Guys with 4.10s and OEM tires
- Re Race gas in SC C-6
- Race tire for streets/Hoosier A6
- dyno results from bolt-on's
- anyone know the difference between these two gm head gaskets ?
- Any HP gains with cat back?
- Fuel Line Fittings
- B4 and after dyno numbers A6
- Chose my cam!!
- catalytic converters burning up. help!!
- Z06 Shocks on a Z51 C6
- Problem after headers and gears install,help!!
- ceramic brake pads
- cold weather and detonation?
- maf screen observation
- tuning a C6...
- Do you have a Vararam, DID YOU GET A TUNE?
- VARARAM SPACER w/ VORTEX?
- Will 2006 C6 3.42 diff bolt up to 2005 A4 C6
- Getting in 2nd gear is not smooth!!!
- proposed mods
- AFR 225 OR 205 for this cam?
- Vararam Filter
- VaraRam Snake Charmer, HallTech Stinger, SLP BlackWing
- Z51 v M5 spirited run
- MAF went bad - Thought I Blew My Turbos!!!
- !!!!The Winner OF American Racing Headers!!!!
- Squeaky Clutch Pedal...
- C5 Z06 Wheels Rubbing at Track
- 2007 A6 7th gear??
- Anyone have an HP Tuner?
- o2 sensor plugs
- 160 degree thermostat & Vararam throttle spacer ring
- Who's running the best ET's with basic bolt-on's?
- corsa exhaust popping
- 2007 brakes
- feedback on cometic head gaskets
- c6 backfire pop on decel after procharger
- Anybody replace a low beam bulb yet?
- Key FOB Question
- Hallteck cold air induction kit to go with my stinger?
- C6 2007 Questions and Statements
- Low Torque and Headers
- Tuned
- Tuning options
- Post your A6 track times?
- Z06 rear fender question
- Can I get the straight talk on headers......
- Changes for '08?
- Electrical Xperts, come on in.......
- Whats the differenxe between o6 and 07 C6?
- Engine rear main seal leaking
- FYI for 07 owners
- Orange light by passenger sunvisor
- Borla Z06 exhaust on C6
- I Need Help Asap!!!
- Base Line Dyno Today
- A6 Tuning???
- Pressure sensors for Z-51
- ls2 edit
- Traction Control
- TIRES: Run Flats vs. Non
- Dealership put in new rearend today.
- Any Flowmaster Pic's?
- It's Crunch Time for A.R. Headers Giveaway!!
- Tire sizes and traction ?
- Wheel size on Z51 (18X9.5, 19X11)
- Anyone with LG longtube headers WITHOUT cats??
- DIC Codes
- CAGS and Check Engine Light
- Clutch spring adjustment or Slave cylinder anyone else with problems?
- A question for 05 mn6 supercharged people..who had DBS BEFORE install
- MAF Help Needed
- lowering a 2007 C6
- Need opinions on these cam specs
- Installed Honker in C6
- C6 brake job
- C5 rear wheels on a C6
- Two fobs at once?
- Kooks LT headers and O2 extension length.....
- Announcement (Gene@FredBeans)
- Anyone know PN for C6 Z06 rear sway and insulators?
- A6 with Kooks new best
- Oil leaking from rear end
- Base Dyno A6
- I wanna go 200mph!
- How do you calculate top speed?
- Engine Light
- Poor track conditions = major damage
- What's my car weigh?
- What mod next?
- Question about Z51 brake rotors and calipers
- Who has an MTI 6 Shooter?
- Fog Light Replacement - Access?
- Upgrading standard C6 Swaybars
- C6 Parts Manual?
- A6 Exhaust Systems - What Are Your Feelings?
- Maggie
- FYI Problems from the November GM Tech Link
- Heads & Cam Video
- Gauge mounting ideas...
- Vendor Rating System
- another cam question
- Encounter with a ZO6 is he a forum member??
- Front O2 sensors, flat or square connector?
- Testing out a non catted system, what should I do with O2 Sensors
- What would you do to the motor if you could?
- Kooks LT headers and O2 extensions.....
- Need help installing a B+B x pipe
- 2008 450HP 0-60mph?
- computer tune c6 2006
- Race pads and street pads - same rotors
- need help with brake ducts
- vararam + s/c
- E-Town Today - One More Time in search of 12.4s@117+
- New Dyno Numbers w/ mods
- C6 Shifter VS C6 Z06 Shifter Debunked
- Z06 Tran & Diff capacity
- 2006 C6 MN6 Slipping in 3rd, 4th when cold?
- Mustang Encounter
- Mustand Encounter
- Forgeline's First Time Ever Wheel Sale!
- New First Gear
- LG PRO LONG TUBES @ Corvettes of Westchester
- Porting Stock Heads
- Long tube headers and emession
- Borla C6 Z06 cat back
- ** OK, Who is going to PRI? **
- Moroso "Private" Drag Strip Test Day 11-24-06
- Vararam Air Cleaning
- Technical Question: Self Cam / Heads Install
- Vararam?
- Wierd noise coming from Z06 rear end.
- Some Questions About The 06'C6 Coupe....
- Headers are on, gears were better.
- Do-It-Yourself Tune - Diablo Sport Predator
- Before & After LS2 MS4 & PRC Stg 1 LS6 Heads!!
- 2005 A4 with 2.73 come in...
