View Full Version : C6 Tech/Performance
- Installed My Exhaust...oh yea!
- Problem using links in the FAQ section
- Maggie Guys Opinions Please, looking to join club
- Exhaust Question
- More Improvements @ TTP - Keep Yourself Updated on Our Message Boards
- C6 Pod removal
- B-MYSTER Revalation
- Modified FAST install
- Coilover install
- 3.15 gears
- New 1/4 mile times
- Quick BB Bullet Install Question...
- Getting closer to an LS? Engine with DI and VVT
- Vararam with TBS and Pre-Cut Shroud
- How much horsepower could I gain?
- Got Car Back From Tuner...oh Yea!!
- Need some assistance (AC panel not working) new 08
- Anybody running all 18's on their car?
- any cam regrets?
- New 08, what mods without ruining drivability
- Employee Pricing Special!
- Advantage Base & Z 6 speed
- Post C6 Mod Dyno Complete - Have Results
- A6 Gear Ratios
- Engine Ping on Take Off
- LS3 A/C Drip - Problem Answered
- Tuned and new shifter at Carlisle
- question about my underhood fan
- Predator U7194 question
- Vette-Air Summer heat sale is ON!!!
- Borla Stingers and Touring Sale (great pricing)
- Procharger
- EnglandGreen Cam Package - everything including the Kitchen Sink!!!!
- Z06 Radiator Shroud for LS3?
- B&B and X pipe question
- LS3 A/C Drip
- Slight burrning smell 07 C6 Coupe A6
- Do You Need Thread Sealer On Studs with New Head Install?
- C6 clutch hung up? what happened
- OEM Diff cooler questions
- 29 rwhp for $200 - no kidding
- End Link Question
- Ls3 guys with a bigger cam yet?
- Off season battery maintenance
- C6 rear axle scraping noise
- Purchase $100 in GCA and GM Gives Back $50!
- Differential noise
- Guess my horsepower
- Vararam issues and costs
- RevXtreme Press Release:
- Z06 axle back
- SP3P ForgeLine's in stock and ready to ship NOW!
- Manual Trans Issues
- stocks c6 vs slightly modded audi s4
- Weight watchers
- any results in the '08 vs C5Z06?
- fastest vette ever??
- '08 / LS3 Project - No Internals
- Dicks LS3 hey come back man!!!!
- Diablo Predator
- GT500 vs 08 vette !
- Is this for real? GM supercharged v8
- tire sensors
- New 08 1/4
- My Ferari vs. C6 !
- ETC Throttle Area Conversion Help
- Help w/HP added ?
- Recommendations for 08 mods-road course
- c6 door mirror prep for paint
- Z06 Brake Conversion Instructions
- Borla Stingers - 08 LS3 - Excessive Burble/Popping on Decelleration
- Z06 sway bars
- Wish me luck, I'm going in...
- Where is my vette
- Issues with denso o2 sensors stripping
- Battery chargers/tenders
- Interesting Dyno---K&N Filters in stock intake
- Want a conservative front alignment
- Tire?
- C6 durability questions
- who said a catback wasn't worth any hp??
- Looking for info (TSB's etc) for 3 different issues.
- Q? O2 sensors front and rear are they the same?
- center console
- New 08 1/4 times !
- Steering wheel plastic pieces - removal.
- Vette-Air Installation Problem with '08 Z51 Oil Cooler
- A6 sluggish paddle shifts
- Z51 M6 Trans Temp ?
- Differential Oil Leak (2006 Coupe, mn6, 17,000 miles)
- LS2 - 395 or 400 hp?
- 05 C6 header gaskets
- Jeremy Formato finally slays my KR issues
- lapd tunnel plate
- Factory PCM
- Secret of the Mystery C6 1/4 panel bags....REVEALED!!
- best price, koni sports
- Store Wide Sale Extended Until August 29th!!!
- Bilsteins on a Z51?
- C6 External Oil cooler
- BFG drag radials on 18inch wheel
- Headers without cats?
- SLP underdrive balancer pulley on LS3?
- Procharger low clearance fix
- Which Headers???
- cam with 4.10's driving impressions ?
- Cartek and Torque Management
- Carlisle Pics # 7 - Misc. #3 - Final
- Homelink
- catalytic converter blow out?
- C6 / C5 Clutch Pedal Spring - More Info with pictures
- Oil Filter Torque
- Got my car back - A6 replaced 15 days later...
- Lugnut socket size
- Anyone have GM Performance mufflers?
- Plastic Bags in Rear Quarter Panels
- Which first, headers or 4.10 gears?
- Roger and Jeremy at Horsepower Sales
- C6 to Z06 Brakes Conversion
- Will C6 Z06 Brakes fit on a C5?
- NPP Question
- 1/4 mile times on 05 751
- Lost small clear plastic fill tube in my M6 Trans - help please
- Warm air flow by the leg?
- 2008 Key Fobs In Stock!
- Thanx Corvette Specialty! Dyno numbers in
- C6 Slective Ride
- Would the c6 smoke a 03-06 E55 Amg ?:
- Naturally aspirated mods?
- need suggestions for 4.10 upgrade
- Next Level Performance (nlp) Bigger, Better, And More High Tech.
- Question on Kooks with a Magnaflow 15884
- SpeedDirect Labor Day sale
- Halltech whistle
- 06 C6 Driver contemplating getting a 08 !
- Transmission experts - please give me your opinion.
- Corvette C6 Mods
- Anyone Race a LS2 Vette vs.LS3 ?
- Air flow problems with aftermarket intake systems??
- Help with Kooks headers
- 18" Rear wheels on '08 Z51?
- dead battery now onboard computer dead
- Finally got my B&B Bullets on, with video.
- Z51 Zinc Coated Rotors
- What size is the threads on the fuel rail (schrader valve) of the C6?
- Mix Mizer syringe
- Will C5 z06 wheels fit a C6?
- Break-in for remanufactured transmission?
- Initial Sluggish Start Question
- '06 Lifter Noise
- Norris Motorsports New Location and Grand Re-Opening Ideas
- [looking for] '08 C6 TUNED Results w/ or w/o mods
- Rearview Mirror Upgrade
- tire pressure sensors the same w/in model years?
- FRC "corvette" letter the same between 2007/2008? (Forum dealers, help!)
- Free $500 Dyno Tune w/Headers&Honker package!
- ***DEEP Discounts For Most Products Thursday/Friday Only!!!**
- Is there a tuner near minneapolis?
- Help!!
- LSX block ? ?
- Z06 CAMMMMM!!!! Best set, price and passes the sniffer!!!
- Lousy times at the dragstrip tonight
- K&N intake on an 05 M6
- 175* T-stat?
- GM high performance oil pump
- Dragon Race Engineering Whipplecharger?
- Gear on 1/4 mile times
- Headers and Emissions?
- *WARNING* APS C6 Fuel System Failure! (photos)
- Mid Engine likely for c7
- RevXtreme Hot Cam Package Special!
- Corvette z06 size wheels on a C6
- Temp Gauge Fixed
- Just had a Magna Charger installed how are my numbers???
- Wilwood 6-piston 14" Front 4-piston 14" Rear Big Brake Kit, Red Calipers
- Sewing Machine...
- Rear spring part # validation
- Torque specs for valve stem nut??
- Kooks To Display At Carlisle
- WARNING! Performance Addiction
- O2 sensor issue!
- Need Help with Cam Upgrade
- Who Uses The Diablo Pred. Prog.
- A4 Change to A6 or MN6
- Callaway v/s WCC
- X Pipe Insulation
- Weird clicking noise when pushing in clutch
- Doing Z06 Brakes - Need instructions.
- Can dealers get BRAND NEW (A6) 6L80's?
- Professional Products Typhoon
- Z06 Mufflers
- Part number for Hyper 160? I did search...
- Are LG Headers what I need.
- Crystal Red and Jetstream Blue License Plate Bracket/Holders Available!
- Headers 1 3/4 or 1 7/8
- 2008 Key FOB's Available!
- Does 4:10's mean new clutch?
- Anyone installed the Motorsports Technologies Inc Stealth II Cam Question
- LS3 CAI options?
- Which exhaust is LOUD?
- Does PCM Control A/C Compressor
- Rear Spoiler
- Vararam at Carlisle with Corvettes of Westchester
- Need Help w/ Clicking Noise...
- Supersprint exhaust
- Please describe rear end chatter (no taco bell stories)
- Best Bang for Buck? Cam or 3.15's
- C6 Z06 Mod Help
- C6 Z06 Mod Help
- HOLY COW 4.10 rear for 06/07 C6 at CARLISLE
- B&M SHIFTERS INSTALLED IN YOUR C5 or C6 CORVETTE @ CARLISLE THIS WEEK! by Chuck CoW
- supercharger
- C6 z06 big brake kit on 19x10 and 20x11 CCW wheels
- Front Wheel noise
- short throw shifter and zo6 sway bar for c6
- DIC Hot Engine AC OFF!!??
- Quik Question: Correct Oil Filter???
- power seat dead
- Z06 Brake kit & wheel options?
- Do you think the '09's will dyno higher than the '08's?
- Will thermostat or tune void warranty?
- The Vette-Air on SALE for only $124.95!!!
- Climate Control Blinking:
- Whats your Dyno #'s?
- help on removing wheels.. what size lug nuts? 19mm or 3/4 inch?
- 2008 Dual Mode Exhaust
- Who has done business with Central Florida Motorsports?
- Painted calipers?
- Z06 brake upgrade
- side vents
- Idle LS3
- dead battery
- Longtube headers with factory '08 X-pipe?
- End Of Summer Installation Specials (New England Area)
- just got 08..... need help
- A6 problem anyone had this?
- Service Charging System???
- Shift points for your A4, 315?
- motorsport wheels "HEAVY"
- Idle Problems Help Help Help Help
- Who Knows For Sure: Std Shocks From A 2007 Fit A 2005?
- Can a cam "slip" out of adjustment?
- Private track rental at CA speedway
- C6 Hoodliner question
- What should i expect in 1/4 mile
- CAI & heavy rain?
- Question for the tekkies
- Computer problem with my C6?
- 05 Center Console Removal
- RPM dipping
