View Full Version : C6 Tech/Performance
- 2009 C-6 LS-3 no start.
- Random shutdown problem...
- how to close a door without battery?
- Low brackets for tall guys with stock seats
- Tie Rod Ends Vs. Heim Joints
- Help with Spark Plug Heat Range
- Rods - Texas Speed vs. Scat vs. ????
- Air con and oil pipes
- Idle of 2013 Grand Sport 6M
- upgrading my 012 G.S. I need some tips.
- Vengeance Racing Twin Turbo C6Z lays down 8.41@166mph
- C6 convertible top won’t close
- Transmission and Differential Oils/Fluids
- C6 2007 convertible topic won’t close.
- strange clacking after changing battery
- NPP Muffler "Upgrade" ?
- LS7 Head Dimensions
- ABS Traction Control C0561 Symptom 71
- New vs. OEM brake calipers
- what is this part?
- Need two attempts to get A6 into park....
- Weld rts rims
- Squeak noise coming from rear passenger side
- what is the normal oil temputure
- 08 Z51 concerns
- Corbeau A4 seats in C6 Help ...
- TPMS not reading can't reset ?
- MTI Custom Camshaft Kits
- What spark plug for LS-3 427
- ABS/TC/Active Handing warnings
- Photobucket finally relented....
- Clarification on M6 Trans and Diff Build
- Warning: 2007 Owner's Manual and 3-volume Shop Manual wrong about programming key fob
- T56 won't go into reverse when cold/sitting
- ODB II Information
- check engine light / wont start
- 2012 GS Service Traction System - Service AH System
- What is good engine temp for 08 LS3?
- Tires
- Help! Knocking noise after two months not running
- Head and intake decision
- Stock 05M6 had intermittent start now no start
- BCM or ECM problems- need vettepert/expert help
- Best muffler for ls3-525 hp in a 73
- Rpms not going above 4500
- Mouse nest in C6 Headlight- '06 Convertible
- Mouse nest in C6 Headligt
- LS2 with minor mods. Worth a tune?
- HUD install
- Expected horsepower on the following...?
- Sealing through bolts on MAST heads
- looking for a how to on digital gauge wiring install
- 2005 c6 corvette not turning on any help
- Passenger Side Hood Release
- How to Reset Anti-Theft Locked Radio
- 4.0 amp parasitic draw
- Dual mode exhaust / Z51 service
- C6 top won’t move
- Whipple Supercharger Kits Now Available at VIBE Motorsports
- Where does this red wire go?
- EPA Fines Tuning Company
- 2012 GS Dry sump oil pump Replacement
- Corvette C6 steering gear assembly PN
- Sony xav-ax200 head unit installation c6
- Home link
- abs light flicking, column lock light, and tons of misc issues
- 10.5 volts while running
- Brake Dust/ Hawk Performance Brake Padfs
- DIY Alignment Tool Kits- need to pull the trigger soon
- •► CoW BOOSTER - THE MOST AMAZING C6 PRODUCT EVER OFFERED - IS NOW TOTALLY FREE! ◄•
- PPS sensor help
- Doing a rear only OEM wide body kit, so..
- Aldan American Install with Measurements
- C6 ECM location
- what is the best heads for my engine
- 2013 GS front spoiler replacement
- M2W Switch Issues - Fuse Box
- C5 rear calipers bolt onto Z51?
- Runs rich or does not stay running....HELP!!
- C7Z brakes Fitment on C6Z
- Transmission fluid leak
- 2008 A6 Transmisson
- HELP! D3/ProSpeed Heat Exchanger Installation instructions
- 2005 Corvette sputtering and stalling
- Radiator Support question
- Fuse# (park light) blowing under heavy throttle
- ZR1 Wheel Straightening
- Vararam install issues
- Borla exhausts
- Exhaust ?
- C6 Navigation
- Who's at fault here ??
- strange sound testing fuses?.......
- MM Catch can clean side
- Exhaust issue
- TPMS sensors
- AUX Wire route - Kawal
- Sway Bar End Link Adjustment ? (Sway Bar Pre-Load ?)
- 08 with only 6,300 miles, prone to leak?
- Electrical issues here as well ... Blah
- Clutch suggestions
- ZR1 /( FE5 ) Front Sway Bar part number ???
- 4LT dash separating
- Performance Questions!?!
- Getting NPP to Work with FAST Intake
- C6 z06 stainless Steele intake valves
- Anyone who has removed their rear axles want to tell me how you got them off?
- Burns Stainless Lightweight 1-stage mufflers FOR SALE $500
- Question on ls7 starter removal. Video.
- Converting to 17” rears
- 2010 C6 GS Convert Callaway 606 wont start
- Front Steinjager Sway Bar End Link Installation Question
- LS7: Whistling from Halltech intake
- Walker lap-joint clamps
- Can Battery Be Maintained Using Jump Start Connections?
- 2007 vette, engine light on, vibrates, etc.
- Car dying while driving with no indication! Fuel pump?
- Oil Temp higher than usual (250F) when easy driving
- Oil Pressure acting funny.
- ZR1 axles or DSS axles for 1000hp
- C7 seats in C6?
- Factory Ls3 rocker failure not sure what’s going on....
- What is the correct hub bore for a C6 ?
- For 2006 Convertible; what is it ?
- FS OEM C6 Chrome Center Caps NEW
- ?? Active Handling Light - Rough Running
- NAV & XM Antenna
- Thoughts on deleting z06 oil cooler
- Exhaust manifold help please
- Utters ?
- Sudden strange sound from rebuilt 1500sl w only 175 miles
- Rear Hatch Lamps
- Ls2 to ls3
- CAI vs. AAI
- Low Cost Submersible Fuel Hose
- LT header install cost in 2018
- Help and Tips! First time to the drag strip with my 09 Z06
- What would you do?
- Clanking noise from rear end.
- Fuel system monitor will not show ready
- ExtremeOnlineStore | C6 Z06 Front Splitter Ground Effect - Best Price|Free Shipping
- Hydraulic Clutch Line Tear
- C6 Battery terminal replacement
- Euro to US tail lights help
- road race tires 200 tread wear for a Z06
- If you still have stock wires in your c6 you should watch this video.
- Running like garbage with 02s plugged in.
- Swapping grand sport brakes onto my 2009 base vette
- 05 c6 starting up issues
- Airbag Circuits Steering Wheel
- Rear Shocks
- 2007 Z06, whine at higher speeds, cannot modify sound
- ExtremeOnlineStore | C6 Z06 Front Splitter - Carbon Fiber/Carbon Flash/Primer Black
- CHUCK CoW's BIG HURRICANE AutoCal & CoW BOOSTER! Tuning CAN'T BE BEAT for C5,6,&C7 !!
- Wheel speed sensor errors & uneven fender gaps/rubbing after HB & pad/rotor swap
- Help Identify Part
- redtop might be failing,,opinions
- Help on how to remove tube between fuel tanks
- Just Purchase My Frst Corvette
- Harmonic balancer replacement advice - Ventura County
- Lost the Pop/Burble in Exhaust
- Hesitation when starting hot, sometimes won't start!
- Just installed RTK TR6060 Stage IV 5th gear whining.
- Help me understand fan module testing
- Has anyone ever converted a S/C car back to stock? How did it go?
- Looking at Dewitt's Radiator for 2008 Base C6
- window stopped working, passenger side, 2005 c6 coupe
- One-to-four shift
- Z06 Caliper bleeder repair
- Loud to Quiet Mode Exhaust
- Harmonic balancer is going: HB replacement vs adding a cam?
- Variable Speed Sensor issue and no Reverse
- C6 Magnetic Ride Delete - Couple of Questions
- Painting Calipers
- Service tire monitor system message
- American Racing Headers Group Buy at RDP Store
- oil change, obsessive? OCD?, maybe normal?
- Exhaust Question
- SW Florida performance shop
- Lingenfelter Heads and/or GT11 Cam for LS3
- Attaching two Fan Control Modules in parallel
- I have a ONE of a kind problem. Dealer and Research can't figure it out Please HELP!!
- No erl ls7
- [VR] Heads/Cam/Header Grand Sports makes 502rwhp and 455rwtq
- Vacuum source location help
- Stellar Remote Start
- tranmission problems
- Shifting Noise with A/C On
- Aluminum pulley options?
- C6 Drivetrain power handling capacity? (Auto or manual)
- Answer me this riddle
- C6 Automatic Transmission Shifter Linkage Bushing Temp Fix
- bad battery or something else ??
- 15” conversion question
- Battery Replacement
- 6L80E stuck in 4th gear
- Clutch Advice 520/480ish hp/tq C6 LS3
- Next Mod
- Let's talk stroker motors
- C6 fuel gauge dead after pump upgrade
- Vbox performance box results?
- LS3 A6 Weird transmission issues
- Active handling turns on after I have turned it off
- Cam swap/ lifter ??
- Hydrolock - Compression test results
- Trunk does not open on first release - 2006
- Transmission Cooling Kit
- 2011 Grand Sport w/NPP - Looking to upgrade
- help needed to identify right or left fuel sending unit
- 2019 c7 wheels gs for c6 gs
- 08 BLUE TOOTH set up??
- New NAV disk
- Move rear O2 sensors to front?
- LABOR WEEK SALE! Performance PARTS!
- Spark plugs
- Fuse # 10 for the Dual Exhaust Mode keeps blowing
- LG Motorsports Headers In Stock Ready to Ship
- Cam for fast et's fbo ls3 m6 car
- New GM windshield, dash pad wrinkling
- C6 Low Beam Passenger Dim Help ?
- CW4L and Forgeline Wheels September Monoblock Blowout USA USA!!
- C6Z Intermittant Problem
- Best pass so far, 10.58.
- C6z brakes on c6 base which wheels to use
- looking for knowledgeable, reliable mechanic
- ***Labor Day Sale***
- CULTRAG Performance Labor Day Sales Event. Save 10%.
- Advice for max effort Z06 Build
- C6Z Vararam
- Key fob reader
- Airbag sims anyone else sell but Vetteworks ?
- ExtremeOnlineStore | C6 Exterior Parts & Accessories - Best Price | Free Shipping
- Steering 'Feel' Question
- Bad E38 ECM - it happens
- Rattle in the front end - end links?
- z06 mufflers on base
- Cig Lighter Fuse Question
- Suspension Upgrade Options
- Add Z06 shocks/springs to base?
- Thermostat replacement question
- C6 GS Brakes and Rotor
- Adding NPP to a non-NPP C6
- Part # GM performance parts wires for LS7 motor?
- Early Z06 cooler
- Two Different ACDelco Intake Air Filters For LS2
- Purchased exhaust at Carisle
- 2008 cooling fan starting to growl
- Randomn misfire P0300
- Water Pump Failed. Replacement/Install was an easy DIY!!
