View Full Version : C6 Tech/Performance
- Any one know of any deals on corsa sport exhaust
- 92mm vs 102mm manifold on LS2
- Track wheels for Z06 18" or 19" rears?
- ZR1 cam in ls2
- Tune-up
- Z06 exhaust vacuum control?
- Long Beach Grand Prix > PICS> ITS THE PITS
- Air Filter
- *** NEW RELEASE: Smooth Flat Top Billet Valve Covers ***
- ZR-1 or RPS BC2 clutch???
- Before and After...
- Best tuner for 05 6sp
- 93,890 miles and my Driverside door won't open
- DBA 5000 XS Rotors...front...DBA 4000 XS rear.. 08 Z51
- Spring is here, time to spend money. Some questions...
- Bilstein sports or HDs?
- Going to Buy GS/Need to Beat GTR??
- any ls7 cam install write up's DIY
- ZR1 Cam in an 08 LS3 6spd Auto?
- Air bag warning light
- 3600 Converter or Not ??
- Anyone know anything about play in my steering wheel
- **SPECIAL** ForgeLine wheels for Corvette Forum members only through LG Motorsports
- strange problem 2005 C6 Z51
- Please Help Deployed
- Ideal Way to Install Front Tow Hook on C6
- help c6 convertible trunk dont open with remote
- A4 Yank 3200 vs 3600
- Major differences between the A4 and A6 Tranny
- A6 Trans Temp.
- Drive train strength?
- Zr1 exhaust Mod
- pushrod help
- DIY: Stow-Away Emergency Jack
- 2005 C6 Radio/Nav problems
- GP on Racestar drag wheels!
- Stainless Steel Braided Brakelines
- LS7 clutch on base 08 c6?
- 2005 c6 AC problem
- LS3 dyno numbers...headers, stock intake...
- LG GT2 exhaust
- Intake Manifold Removal Steps
- How to drop the front cradle
- Instrumentation gone crazy on 2011 GS
- Some Corvette Roadrace action. {Tripple angle HD Video}
- Hey Spinmonster!
- dual mode not working??
- WOW! I just gained 75-80 AMAZING HP
- Who has the best price on a Fast 102 ?
- DIABLOSPORT TRINITY TUNER Z06 Is It Worth Buying??
- Stoopid Chimes!
- Have some dyno numbers
- Bolt-on Manual C6 in the 10s...
- *** St Jude Auction #34 Retro Poster Prints***
- Super rich smell at idle, killing everyone!
- The QUALITY MOTORSPORTS spring SALE is here
- Brake Fluid specifications
- drag setup for c6!!
- I have a LS7 Short Block...whats it worth?
- Performance upgrade
- Got sights on a 05, any issues to be aware of?
- A/C Problem
- Best battery for the C6
- Billet Racing Pedals - Group Purchase - Satin Finish
- Heads and mild cam - stock exhaust
- Autometer boost harness help?
- Opinions/Experiences with Airaid intake???
- LS3, Headers, About to tune...Aftermarket intake or not?
- NAV MP3 Static Fix
- Problem when the Stoptech brakes get wet!!!
- Big shout out to East Coast Supercharging
- Wheel & Tire size and fitment differences between stock and ZR1 style?
- column lock not locking - bad?
- what brand 3.42 gears for a c6 with a6 trans
- Long tube headers with stock mufflers ?
- FRC's for a Fast 102
- 07 Z06 with LG headers and tune only
- battery replacement
- Looking for Dyno tune
- Russell C6/ZO6 Stainless Steel Braided Brake Line Kits Only $119.99 a set!!!The BEST
- Make your A6 shift correctly!,
- Where does this Connector belong to?
- Weight of GTO/C5Z drag pack
- Nav/speaker installer Baltimore area
- Spark Plug
- 08 Head/Cam LS3 hits 178.9 in the Mojave mile! {Video}
- Ball joint replacement question
- Drag pack ready for 10s!
- Help with Tie Rod Ends
- **Now Available Black ZR1 & Spyder Style W/ Red Lip**
- 2005 LS2 Air Intake - Upgrade Ideas?
- ***RELEASE** NEW ForgeLine GX3 Wheel
- option not available code help please
- LG Street Series For C6 Question
- traction control system&hard shift
- Lugnut torque specs 2008 ZO6 front and rear rim
- Floor jack position to lift for jack stands
- Looking for used crane valve spring tool
- Battery Intall question
- LS3 dry sump balancer vs LS7
- HOw much Power will i pick up with heads on cammed ls3?
- Looking for paint ideas for bottom side of hood. What do you have?
- NEED HELP! Engine sound advice
- Who is your average take-off Z06 / GS wheel & tire buyer?
- Blu808 Exclusive Forgeline pricing. Including the radical new GA3R racing wheel
- Stock Ported LS3 manifold vs Ported Fast 102
- installed my LG longtubes
- Rear Tire Wear
- Injector upgrade without Procharger?
- Zo6 Brake HELP!!!!!!!
- 2007 Convertible Top Hits Tonneau
- New hood came in WOW. Now the hard part
- Need help with parts list LS3 long block
- Swapping axles...more questions....
- Vararam Shroud Template Dimensions??
- 2006 C6 Brake help please
- Supercharged LS3 life expectancy?
- Alignment after bearing replacement
- Fixing Glazed Brakes
- 372/356 seem low to you?
- Messin' with some powder coat colors and thought you would want to see
- Belt tensioner on 2007 C6
- Brake rotor upgrade?
- front tire size?
- Stock bolts in or out to lower?
- GS Coupe
- **Another 700+rwhp ZR1 Corvette from Late Model Racecraft**
- Fast ?
- Speedometer Panel Question
- Brake time, have a few ?s
- LS7 Chips or Programmers?
- Laser Interceptor Quad Install [Pics]
- **LMR at Texas Mile Video**
- how to access gas door cable?
- C6 Knob bolt specs?
- Mirrors dismantle
- K&N Stock Replacement vs GM 08-11 C6 Air Filter...the winner is????
- wheel offset issue
- Any Fast102 with stock LS2 Throttle body numbers?
- Vette mechanic
- Speed Shops in Minnesota?
- Help!!! Slave Cylinder clip.
- Thank you all for your response
- r888 tire pressures
- Found unconnected wire ?
- Noise related to Air Conditioning
- Corsa extreme question.
- Where in AZ can I get my PCM flashed after mods?
- Any F55 owners (non Z51) installed Z51 Swaybars?
- Ride height question
- Stock C6 to ZO6 size Wheels and Tires - What kind of RWHP Loss?
- Z51 Sway Bar Kit & 2011 Z06 Shocks Sale - www.PartsTaxi.com
- noisy tires or bad wheel bearing?
- A6-Running a sep. tranny cooler & need connector specs Please
- Stock C6 LS3 at Mojave
- Regular Gas vs Super
- Putting car in nuetral 08 vert auto
- Weird ABS issue
- Tryn to drift my car
- What size tire are you guys running on Gto front spares
- Low Beam Replacement Bulbs
- C6 ls2 m6
- Purchase a set of LG Motorsports headers and get a free gasket kit and shipping!
- Plug wires
- Blu808 X LG Motorsports ripping up the streets of Long Beach !!!
- Tick adjustable clutch master cylinder (Hinson)
- Which rotors?
- RX Performance Ported Throttle Bodies.. worth it?
- April 2011 C6 Specials @ GM Parts House
- We Sell Complete & Fix All GS/Z06/ZR1 Conversions @ GM Parts House
- FAST 102 and NW 102 install HELP
- Bolt size / pitch detail: torx-bolt for seat belt to b-pillar
- Fast flashing turn lamps
- help!!! Ls3 headers on ls7
- Getting message I cant read
- C5/C6 Diff conversion bracket......UPDATE!!!
- FAST 102 on LS2 - map extension
- Z06 brake help
- Aftermarket Rocker Arms and Valve Float
- AFR 210 or 215
- LS7/ Z06 Low compression heads?
- 05, A4, Gear Selector Problem & Now Vet Does NOT Start, Please HELP!!
- 315/35 on a 17x9.5???
- Hawk Brake Pads - Lowest Price Guaranteed By 10% @ GM Parts House
- Best OCTANE BOOSTER?????
- LS3 IM porting
- axle strength ??
- Where can i get jumper harnesses for seat removal
- Top 10 things to do with a Tech II
- Harmonic balancer ?
- LS2 lifter orientation during install
- CAGS bypass problem
- Cammed 2007 Vette
- How do you connect the C6 oil cooler hard-lines into radiator?
- **Late Model Racecraft Corvette makes 905rwhp on nitrous**
- t56 recall?
- Billet fuel rail
- Jet Powr-Flow Mass Air Sensor 14whp bolt on?
- Update on LockPick 1-Pod.1-Phone product
- Tire pressure - non-runflats ?
- Nitto NT05R vs. M/T DRII
- 3" down to 2.5" exhaust question
- Tunnel plate... I have an idea. Will it work?
- Anyone have a tune for FIC 108lb injectors?
- Headers hitting steering shaft
- insight on a C6 twin turbo kit
- What BCM nannys can be disabled?
- Throttle Body Motor Question?
- How do you change the transverse (leaf) springs?
- Dual fuel pumps....How do I pair them up???
- Noise in dashbard
- 05, A4 Gear Selector Problem
- Keep the Coilovers or not?
- Clutch Spring - 2011 GS
- Notchy transmissions
- **Now Available Matte Black Spyder Wheels In C6 Sizes**
- 2006 Rear Wheel Noise
- Quick Stereo Question
- Dash problems after HUD & PXAMG installs
- The tale of a blown LS7 that (thankfully) wasn't
- What brand OIL do you use?
- ***** St Jude Auction #30 C6 Mobil 1 Corvette Racing Oil Cap***
- Fire
- xm antenna location
- Blu808 LG Motorsports GT2 Coilover Special Package
- Need help!
- No oil pressure?
- quick question (help)
- E85 Gas Cap
- What's faster? Z06 or 2003 srt10 viper?
- Got Lope?
- Pfadt Racing now carrying 8.5" Quartermaster Clutch kit
- Weak Performance after Battery Replacement
- Lowered the car...now the passenger side rear squeaks.
- GT2 Carbon fiber Rear Diffuser For Stock or Aftermarket Exhaust
- 02 sensor wiring (universal?) what color
- Clutch Install
- Where to buy front skinnies for my Z06
- LS 376/480 cam in LS3 under warranty?
- Need More power ls2
- C6 Corvette Exhaust Systems
- Oil pan gasket leak
- Maintenance Cost
- harmonic balancer weighted?
- Fuel pump upgrade choice?
- 2 Piece Rotors..For 08 Z51...
- Ordering an engine soon...
- Which gear to Dyno in for A6 with 3.42 gears?
- Jet Hot coatings
- c6 open headers?
