View Full Version : C6 Tech/Performance
- New Castrol Edge 8x better wear protection than Mobil 1
- F55 shocks to conventional shocks
- Tire ?
- Michelin PS & tire sensors
- Vortex Air Ram?
- corvettemechanic.com
- New competition c6 package available
- Hey guys back from my extended absence
- 08 LS3 Tune ? 436hp to ???
- Tax Time Specials at TEXAS SPEED!
- Need help with cam info!
- Alternative for cutting stock bolts.
- Anyone make an aluminum TB spacer?
- Engine Porn (Pics inside)
- Cam Advice
- Re-Index Windows???
- How much RWHP will a stock Transmission '08 A6 hold?
- cALLAWAY Honker
- $2,100 for Ported Heads
- Money no object heads, cam intake and dry sump
- Injector resizing by FICINJECTORS: GREAT SERVICE!
- Nissan 370z vs 2008 Coupe
- Sebring American LeMans winter testing Video from This week
- Need help selecting a camshaft and supporting modifications for my 08 LS3. (PLEASE)
- Does anyone regret replacing their camshaft? If so, why?
- Fuel gauge problems
- Halltech C6 Killer Bee Conversion Package for the 05-07 LS2
- F55's with Z51 sway bars question
- '05 Engine Won't Crank (turn)
- Anyody know a portable dyno company?
- Performance Clutch???
- Possible Brake Caliper Problem- Video provided for analysis
- Z06 Exhaust on LS3 - Dyno Results?
- Z51 Brake Caliper Brackets same as Base??
- ***Straightline Performance LSx Cam Special***
- We are having an injector sale
- tire question....30mm sidewall in the rear ok?
- Engine prices at EPP
- Full Engine Port??
- 1/4 mile suspension?
- Dragging Noise
- 1 3/4" Vs 1 7/8" Header Swap Results.
- Just lost Reverse!!!!!
- How Loud will this Mod be ??
- Easy way to increase HP and fuel consumption
- What size drag radial for 18x10.5 Z06 Replica?
- AR Headers install! Help!
- Bondurant Instructor's analysis of the Corvette C6 Z51 Package
- Ported heads
- PRI 2008 - Lots of Pictures
- TIPS Tool
- Corvette Options for 2010
- February Porting and Tune Special
- Brake Bleed
- Valve Piston Interference Pictures
- Failed Timing Chain Pictures
- Anyone purchased a LME Engine that had problems? Check this
- Need a Euro Navigation Disc ASAP.
- Vbp is having a sweetheart of a sale
- The 600 HP Club!
- What to do first?
- Clutch Sale @ KY SPEED - Textralia, McLeod, SPEC
- Replacing the front spring
- Navigation Disk Ver 5.0
- Need Help in My car factory OEM Navigation Unit
- c6 spoiler
- LS9 Engine Info
- Mystery Front End Shake
- New to Forum, Just got and dropped off 08 for "upgrades"
- Where to get valve springs tested?
- what tires are best to track for an '08 C6?
- 09 ls3 upgraded why not the ls7?
- Anyone ever had a detonation problem w/ coated headers?
- Zip tie mod???
- What's the highest rwhp on an LS3 Vette?
- C6 with active handling problems!
- 2005 c6 tire advice
- *** CHUCK CoW TUNING in SOUTH FLORIDA - Jan 6-8th * HURRY!!! ***
- wheel fitment help
- Exhaust Install
- Tire balance ?
- Ok final word and update on mgw shifter please read if interested>>>>
- 40 MPG C6, Will it work?
- End link question
- Kooks Headers & Vararam Intake Package - Save a Ton of Money!
- Dbm
- headers with borla question???
- njeed name of trim piece
- HP estimate
- Stingray Chevrolet - Mobil 1 Oil Change - Forum Member Special
- HEADER input, Take II (not normal brands)
- ATEQ tire sensor reader
- Rotorpros Performance Rotors-Anyone use them for $180?
- anyone ever sanded the blade on the TB
- Anyone running the Z06 wheels with c6 fenders
- Sway bar questions
- My car is in a Movie! (Short video clip)
- Which is harder on your engine?
- SLP Headers??
- Unbelievable Accident Report Corvette Wreck
- Halltech C6 Killer Bee for the 08-09 LS3 Onsale!
- Halltech C6 Venoms on SALE for 1 week Only!
- How good is OEM air filter for the LS3
- Under Hood temps in the south?
- Need performance shop in la
- GM Performance Exhaust/Borla
- Clutch help!
- Color matched throttle body?
- Couple moding questions
- Timing chain life on stock LS2's ?
- Headers Install and Tune. Help!!
- CNC Ported throttle Body?
- advice needed
- Which way should the tires roll? Please help..
- Powerlabs' New Shows... Here is how you grip 600WHP on the street!
- My dyno numbers
- New shoes for my Supercharged C6...
- Just Installed Airaid CAI!!
- Experience matters your thoughts on L92 heads
- Your input on BF Goodrich G-Force KDW NT Tires
- NPP conversion of Z06 mufflers 3" to stock 2.5"
- PINKS and Corvettes of Dallas Team-Up
- Z06 wide body upgrade???
- Only a week left on our great introductory offer!
- Coat for Header Bolts?
- whats all required for a cam?
- LG Motorsports HD Quiet End Link Kit?
- 09 C6 brakes
- Cut Larger Holes?
- Kooks Install & Tuning Special @ PM-FL!!!!
- *** LG "Man Switch" Shift Knob - NOW IN STOCK! ***
- *** LG Street Series Headers - SPECIAL PRICING PLUS FREE SHIPPING! ***
- I'm so lazy.........
- converter and gears are in
- BIG PROBLEM:NEED HELP WITH BCM PROGRAMMING!! Canīt start car!!
- Question On A LS3 Spark Plug Change
- custom coil relocation NEED PICS
- 05 m6 ls2 477/410 rw hp & tq
- C6 Z51 Rear Rotor Fit
- Headers/Xpipe/No-cats/Stock Mufflers
- what kind of power am i looking at???
- 2008 C6 M6 Stock Bottom End Heads/Cam Vs 427 shortblock with same heads/cam..
- Anyone go from aftermarket catback to NPP/Z06 mufflers?
- New FAST?
- PRC 215cc Heads - Independent Results!
- Help....Removing Door Lock Button Bezels
- Headers?
- Vararam Quality
- Melrose Headers?
- 1/4 Mi. Stock C6 coupe
- Short Shifter Question
- anyone running the ASA cam?
- Woah, overwhelmed...where do I start?
- OPINIONS on Pfadt "Pfatty" sway bars with Pfadt Pillow Blocks
- Stock C6 Proper Tire Pressure
- Engine removal
- c6 motorsports wheel
- Skidding front tire
- FAST 92 Intakes $830 Shipped!!
- Ar headers + bb fusion + mild 2 wild...with or without cats???
- Those w/chrome '09+ ZO6 Spider wheels or repros, please post pics!
- Blank DRR/Nav Screen
- PRC CNC Porting LS2 Heads & 228R Cam Results
- Breathless Performance New Inexpensive Solution for your Trunk or Hatch
- What is Orange Peel?
- MGW Shifter?
- Vararam question
- Anyone using Toyo R888 305/30/19 on stock rim?
- Which One?
- *********Tax Return Heads/Cam Special**********
- Z51 brakes ??
- Z51 sways install - What did I do wrong?
- 19 inch DR
- Tuning Questions??
- Too Cold to Dyno?
- mirrors pointing down
- Perfomance Chips
- Installing sway bars
- Darn this two tag state
- **LG Motorsports introduces the Sport Track seat!!**
- fuel gauge sender
- Z51 Brakes for 2008 C6 QUESTION "HELP"
- LS7 Clutch good for over 500/500 to the wheels???
- Purchase any SPEC Clutch and receive FREE ARP Pressure Plate & Flywheel Bolts!
- Tko performance
- Dead battery
- Brake Caliper Bolt Torque Specs
- K&N 63-3060-1 Air Intake for 2008 C6
- Powder Coated Brake Bracket ISSUES???
- Smogging a C6 with Headers in Calif
- New Orleans area Tuner? Any out there?
- Question Regarding Garage Floor Tiles?
- Anyone have thier 08 Vette ECM updated by GM?
- Brake Bleeding Question
- help
- Exhaust Question for C6
- Oil Change Base Coupe
- Calling ALL Airaid intake owners!!
- C6 wheel and tire fitment question
- RWHP to expect?
- How do LS3's respond to 1 7/8" headers?
- Need help with a freinds vette
- Torque specs for polished alum stock wheels
- things that go "toc toc toc"
- supercharging c6 ?'s
- 2008 Z06 Mufflers vs 2006-2007 Z06 Mufflers
- Do lifters need to come out for cam install
- Tuning for E10
- ? after FAST install
- windows do not operate properly after dead battery
- 06 c6 makes rubbing sound
- remove rearview mirror
- bolt on mods done 417 rwhp 413tq?
- Need Recommendation For Reputable Trans and Rear End Shop
- 2007 A6 temp reading
- Kumho SPT's Vs. Invo's
- Traction Control Active Handling, Help!
- 2005 rear end housing?
- Z-51 Front Rotor Question
- Intake Question
- Opinions on which catback to get.
- Need Pfadt Coilover preload spring length
- GPS suddenly went out - fuse?
- Turbo Questions
- What balancer has to be used on a 402?
- 05 Outside Door Handle/Pad Help
- Anti Freeze Color???
- GPS Suddenly went out - Is it the fuse?
- Z51 Help!!!!
- MGW Shifter Ordering Question
- Totally Frustrated
- Help with car
- Fellow A6 LS3 racers please check out.
- ls2/ls7 front cover
- Anyone Replaced C6 Battery Terminals ?
- C6 A6/TTi Twins/Vengeance 402 LSX/14psi=759/719rwhp
- E85monster: Conversion for E85
- What ti do with used LS3 motor
- NT555II vs R888
- what gears do I have
- Completely Locked out... stolen keys
- >>> Corvettes of Westchester - STAGE 5 HEAD/CAM BUILDUP <<<
- A report on DMH cut outs
- Install question on Z51 Sways
- Billet Prototypes or Elite Engineering Catch Can?
- DA is -1464 ft right now in Baytown
- leaving a battery dead
- Who should i bet on??
- Want to drive a new ZR1?
