View Full Version : C6 Tech/Performance
- tuning question...
- Baseline Dyno on bonestock 07 M6 today
- Custom twin turbo system we're working on
- C-6 Seat Skins Replacement
- Speed Shop!!!!!
- Fluid Questions
- 07 Service Manuals Available @ GM Parts House
- Valve noise!!!
- Again A&A corvette steps up again and does a great job.
- FYI: Another OBDII Tool...
- Question on adding Z51 sway bars to base suspension.
- Best price for Koni's?
- Dreaded Check Engine Light
- Anybody make an off road pipe?
- Roll Bar for C6 Convertible
- L92 Excitement ...
- Complete List Of Bulb Replacements?
- Baer Eradispeed Brake Rotor >>>
- Do I need a torque converter??
- 0-60 & 1/4 mile predictions w/mods.....
- "New Cam"!!
- Let Us Hear the Growling of Your Vette
- cartek 3x heads for sale
- Header Bolts?
- Are steering rack bushings available
- Whats the best tire ?????
- How wide a rim on a 05 C6 can I go
- Hurricane air intake??
- Lowering bolt accessibility....
- Tony's Corvette Shop Gaithersburg MD...
- C6 Corvette Installs: Vararam, Headlights etc.
- Aero Exhaust
- cold engine noise
- POP! when opening driver door
- Looking for 3M installer
- 2007 Europe Mod Advice
- Sun Visor Removal
- Ceramic coat?
- Opinions on C6 factory ABS,VSE
- Tires
- Question about C6 Vibration
- **Dynotech Engineering (DTE) Differential Group Purchase**
- Tire Pressure Sensor Matching on the C6
- Tps
- Wheel Swap and TPS question
- zo6 clutch swap
- Kooks Header install, would you...
- While we are talking Cartek
- roof rattle- TSB?
- LG Header install: O2 sensor wiring routing?
- Ordered SLP pulley - What Belt?
- Work Done by Cartek
- X-Pipe
- Question about adding Z51 sway bars
- Need to purchase rear control rod bushings
- Clutch Adjustment Q's
- cut outs on a c6 auto
- 1st Gear Grinds
- cut outs
- So what do you polish your Aluminum Polished rims with ?
- Gear Questions
- ** L92 Heads Dyno Results at A&A **
- tire pressure sensor redux
- Dynatech Packages - Now Available Seperately!
- Doing heads, cam, and inake without long tubes
- Service Traction Control System...!!!
- Airbridge question
- Question: How did you run pillar gage wires?
- x-pipe ?
- shifter comparisons........
- urgent help
- Clutch Pedal Stuck To The Floor
- SLP Headers
- Tire shops Denver area
- mod advice wanted.
- Resale of Lingenfelter SC vs DIY SC
- ***Customer results from the track - Mail Order Tune Only***
- Climate control flipping out
- Want to trade exhaust!
- Question for anyone who knows about CARTEK.
- Anodized Rims ...where to go?
- New GM Head, Cam & Intake that won't ruin warranty...
- Will an '05 Driver Seat work in an '06?
- C6 Z06 Shift light demo video
- Chuck Cow Fayetteville Tunearama
- Anybody taken the factory 186mph electronic govenor off their C6?
- MN6 Valve Noise
- Shutting down when "crawling"!
- skip shift
- C6 softwear edit
- Does an aligmnet need to be performed after lowering car 1"?
- A stiff gear shift
- TwinTurbo.......................560HP
- Heads question
- Fast vs ported vs z06 intake
- buying an 05' C6
- WCC Lowering bolts
- Like to share some Carbon Knowledge with CF members
- Finally Tuned --395 Rwhp & Tq
- can you get codes from the DIC
- two things
- clutch problems?
- Won't start need help please!!
- Radio Shack CAGS mod
- 2007 C6 Service Manuals
- FAST or other options?
- Anybody know the part # for the C6 shift knob screw?
- Help w/z51 6spd tranny fill!
- What a GREAT DAY
- Am I gonna hook up better with these new tires?
- I like my auto 6spd C6 but....
- LG Headers Power Gains Question
- Shaner S3 ported TB
- After header install....
- Just finished several mods but the results were disappointing looking for help?
- Rear End Noise Non-Fix in C6 A6!
- Dyno run after FAST install
- When modding, what's going to break?
- proper launch on stock z51 wheels???
- Exidy twin disc clutch?
- Is installing heads a DIY project?
- Plan of Attack. What do you think?
- Are shocks and Sway Bars necessary?
- Switched from Corsa Sport to Borla Stingers!
- Headers: O2 Sensor Questions
- HP Rating
- Is the Z06 Brake upgrade worth it?
- Suspension systems..F55 MR, modify?
- Tuners In Toronto Area ??
- Phantom Traction Control in Comp Mode?
- LG LT Headers install questions
- Race mesh grills??
- ATTN: SCCA Vette Autocrossers
- Where is the additional cooling for the A6 Z51?
- Drag Shocks/Need Opinions
- Is My Mod Math Correct?
- What does it take to put a crate LS7 into a 2006 C6?
- Absolutely Love My New LG Pros
- Paint Match Problem
- New exhaust
- Installed Borla Stinger Tonight!
- Announcement: EG teams up with East Coast Supercharging !!!
- Cheatr cam\Fast\Magnaflow video
- After market hoods
- Cheater Cam?
- LS7 Oil Cooler Info Please
- Honker Install
- **fantastic pricing on Wilwood products**
- Confused on Wheel Offsets
- Shock Install process
- another throttle body?
- Thank you, Grumpy!
- Opinions on these brake and suspens- MODS
- Opinions on attached Defi gauge mounting location
- Rev Xtreme getting me in the 11's
- LGM Header Install Underway.....
- z06 shifter
- creaking brake noise
- TB spacer install results!!
- Window Tint Austin Area
- Al at LAPD is INSANE!
- Best place to buy T-body?
- Z06 Calipers , bolt torque?
- Norris Motorsports Warhawk Block and LS7X Heads Recieved - Project Moving Ahead
- Please Help!
- shift boot...
- F.A.S.T. install results =
- Traction 0-60 / from stop M6
- Which DTE Rear Differential
- Need advice on clutches
- pro charger or heads and cam ??
- Question for the tech guys ??
- Ls2 Intake Work On Ls1?????????
- Finally going under the hood
- C6 gauges not working?
- Alignment ??
- Tire worries please help
- I have no green light!
- X-Pipe
- Jet Hot coating?
- Create your own Forza Motorsport C6...
- Melrose headers??
- C6 T1 Sway Bar Kits Available!
- ECMTUNE™ PROGRAMMING by Halltech
- Need clutch help
- Best wax / polish?
- Why does the STS turbo kit cost so much?
- Headers installed (Link to Photos)
- starting the vette after sitting for a few weks question.
- BMW lift pads
- wiring question
- AR Header part#
- Accident: Need a recommendation for a repair shop
- anyone else think the quality of the Vararam is kinds "iffy"?
- *BEWARE of APSIS*
- help.....with mods
- Surge Performance
- Another wheel hop question
- Header install help
- Engine light after headers?
- Wheel & Offset Gurus come in!!!
- Got my drag wheel setup
- whats the best way to launch an automatic?
- Help!!! Screeching engine noise..
- Austin Tuner
- Underdrive pullys?
- Dyno Results with Tune
- Sudden MPG Decrease
- normal oil temp
- 06 Electrical Gremlin
- Is it better to wait?
- 160 Stat Install Question
- ***All Headers On Sale!!!***
- I think my crank pulley walked
- Anyone driving with L92 & L76 yet ?
- Gene - The Parts Man
- Jeff Nance in Tennessee fixed my tune from MDMC.
- Need shop in socal for Differential install
- C6 Exhaust Options
- Dyno Tune / Mods / Georgia
- Alright A6/A4 guys, who is running a 228 or bigger on stock stall?
- C6 Red Calipers
- Mike Norris Motorsports Complete LSx DynoTune $350 NA - $400 FI
- Thinking of lowering the suspension on my C6
- Best budget wheel for drag racing
- Idler pulley bolt snapped
- Anyone put in aftermarket Nav?
- Rte 66 and ARH's sound clip
- Z06 Wide-body Conversion Poll
- 06 Z51 Coupe Has Rear Cooling Ducts from the Factory!
- Driver Seat disconnections
- Had 07 Vette Tuned Yesterday
- C6 Rear axel bolt-need ideas
- Need Maggie Hood!!
- Best place to tap 12v accessory power in C6
- 11 Inch Rims & Z06 rear conversion.. Speacers!?
- A6 continous torque capacity
- LG Motorsports Experience
- Hit Rev Limiter in full auto mode A6
- Interesting: Hotchkis vs. Z51 swaybars
- Bullet install question??
- 11.05@127.07 on DR's yesterday....
- Any Pix of Stock C6 Goodyears on 1" wider rims?
- FAST intake question
- ☺ ☺ New Release - Medium Geometry L92 heads☺ ☺
- Where to buy roller rocker kit
- Fast Intake or Porting TB
- Any one have heads only with full bolt-ons?
- Where is XM receiver located?
- Unhappy with stock suspension
