View Full Version : C6 Tech/Performance
- Heads up, bought kooks and x pipe
- C6 with G6X3 idling with BnB Fusion Muffs.
- Winterizing your Vette
- ABS / Traction Control Light, C0035-00 Service all 3
- Stubborn Stock Crankshaft Balancer
- What's this tube?
- SC C6 - sputter / stall / gas tank fizzing
- Change Tail Light Bulb
- Headers and Tune
- Z51 Rotors, Please help
- Wilwood Aero 6 calipers and brake line question
- upgraded drive shaf
- C6 Z06 overheating again
- Is my C6 running too hot?
- Lear Car2U
- Transmission Question
- Drivetrain "concerns" in c6 at 650rwhp?
- 2012 Grand Sport AC/HEAT not blowing
- How do I make NPP mufflers functional on a base C6 that didn't have NPP?
- Clutch TSB #14717 gives me the Shakes!
- need help with my tune!!! hp tuners help please
- Help with start issue
- 05 C6 solenoid 1-2, 2-3, 3-4 transmission replacement
- Delta RS27 Fuel Turbopump attachment - more power, uh, uh, uh
- saga completed…transmission failure
- Which spark plug wires?
- New bolt on jack pads for C6 and C7
- 2012 GS 6SPD shift harshness
- Replacement shocks for C6 base
- Power Stop Rotors & Pads
- 900+ whp build. NEED ADVICES! :)
- "Service charging system"
- Steering rack adjustment
- C6Z Drivetrain problem
- Steering Alignment - TOE ADJUSTMENT-
- need gs rear bearing within 2 hours. asap
- Exhaust questions
- LS7 POA Friction Washer
- Final track trip of the year
- Removing rocker panel on Grand Sport
- Rear gear change
- SLP headers
- Poll for question on call out or challenge to a race.
- Best Slotted OEM replacement rotors / Pads????
- 2011 c6 m6 02 extension plug shape
- Remove Headers for Clutch inspection
- Vanity mirror rattles like crazy when driving (cover is not broken)
- New mods what should I make.....
- My bolton list...
- Lloyd Mats for my 2010 GS (lotsa pics!)
- Widen 18x10.5 to 11.5 Rim,tire size
- Where should I be shifting according to my dyno sheet?
- Edelbrock Superchargers
- Want to change rear end gears
- Remanufactured Throttle Body
- High Flow Cats
- 71 Harness Belt
- Cam?
- Stop calling it a recall!!!!
- cam size choice
- Is it possible to have the car sense my Key FOB when I walk up to it?
- Cam help
- ls3 C6 about to go under the knife.
- 2005 corvette will not crank
- Are ZR1 axle stubs different from Zo6 stubs?
- Front suspension question
- C6 Caravaggio Race Seats Installed
- NPP exhaust to which Magnaflow catback?
- LS3 tune only/intake and tune only
- LS7 Fast 102, which rail for LS9 injectors?
- reduced engine power
- Changed brake pads .. clambs left?
- air bag symbol
- help with reasonably priced wheels
- Did new cats break my AC
- Help with part number?
- question about ls2 with ls3 top end
- Father/Daughter Moment, Journey of a Female Driver, Brought to you By Ridetech
- **Update in emission recall**
- 2012 LS3 supercharged stock motor info
- +43 offset for rear wheels - Work on base C6? Thanks for quick reply!
- Is it usually a fulty gasket that causes oil pan leak?
- lets talk brakes setup!
- C6 Suspension Adjusting Screws
- Callaway auto trans no up shift @ WOT
- just bought my 05 beautiful red 6 sp coupe
- LG pro headers leak like crazy
- Was told can't reach 500-550 on ls2
- Toyota R888's for street use?
- My Ranger Method Results - Clutch Fluid Change
- Z51 Pro Street / Light Track Brakes Parts List
- A/c problems
- wilwood Aero6 calipers
- NPP Question
- 2012 NPP on a 2007 base
- SCT tuners? Diablo Sport also..
- 05 BASE tranny to TR6060 info needed.
- Help with start up issue 2012 Grand Sport
- Missing nuts??
- ly6 install help
- HELP!! A6 shifter stuck in Drive & Neutral only
- Lowering Trans Temps
- 2008 Supercharged C6Z broken RR diff output shaft.
- Blinking Check Engine Light Help
- Fasteners
- 2006 c6 Spark Plugs
- Corvette Starting Issue
- Would I benefit by going 2" primaries vs my current 1-7/8" making 900 HP???
- c6 non npp exhuast modd question
- Vararam with Haltech Beehive Heat Shield
- Removable Roof Rattle
- New guy, suspension? probelm
- Complete Street A&A Supercharger Install Special $6050
- 2008 Ls3 p0030 code wont go away
- 2010 Clutch Bulletin 14717
- front sensor
- Why does 2013 ls3 use different spark plugs???
- LS9X Katech clutch.....Sorry Jason
- Fixed back seat with 3 point harness....?
- Diablosport Intune I2 Tuner - New & ON SALE - Free Next Day Shipping or Save More!
- What is this coolant leak? (Video)
- Good shop for custom vinyl work in Houston?
- Clutch Master
- possible power steering issue
- Tick Master cylinder install (My DIY, How-to)
- Katech aero question
- NPP Mufflers
- Problem in door
- ARP Crank Pully Bolt #234-2503
- Advanced Induction TFS230cc heads
- corvette c6 problem...
- Air Condition Clutch Disengeges
- What have you guys paid for a cam install Arond North Ga
- a6 speedo failure at wot
- Oil / Rubber Burning Smell
- TPMS Failing to Update
- Brake pads - Z51 vs. non-Z51
- c6 ls3 coolant overflow
- 2013 GS Shifter Chatters or Rattles
- 2005 convertible hydraulic line leak Help!!!
- LS3 93 octane timing
- Z51 pads/rotors on base c6?
- Volks R vs Ls2 vette ?
- Throttle Body Torx Screws
- Rear seal tranny.sound 08 c6 ls3 manual
- ls2 build
- Steering wheel play
- 05 c6 squeaks until up to running temp...
- 08 @Z51 Suspension, which model of Bilstein shocks should I purchase?
- 575/ 525 on dynojet? Disappointed as hell hell
- Column Lock Eliminator
- Deleting crossover fuel tank?
- Need help finding a part
- 07 A/C question
- 2005 Corvette Clutch Recall - new Oct. 2015
- Newbie question about Heads Up display
- Best street/strip cam 2007 z06
- Hinson and West Bend Dyno
- Identify this hood?
- MBRP Exhaust: drone - How do I get rid of it?
- Any tips on an ls2 cam only build?
- MSD 2 step
- ported ls3 TB now throws p1516 & p2101 on 06 z06?
- Why does my C6z ride like crap vs my old C5z?
- Heads Up Display
- ISP Racing / HALTECH EMS CHEAP
- gm recall 14523
- Any recommendations on bearings?
- Clutch that slips to save tranny
- Fast 46lb fuel injectors for LS2
- Would you guys start with an 83000 mile car?
- Finally!!!!!!!!!
- Looking to get heads and cam done z06 heads and cam set up
- Overheating - What Coolant Fan Wiring?
- 2009up clutch hydraulics, Slave/Master, best practice to replace with 09up.......
- drag radial sizing
- Clutch return spring
- C6 Convertible top issue
- 06 Front Frame Part identification
- very pleased with tuning results! ls3 vette, headers and intake.
- Engine tick - vacuum/throttle affects sound
- Issues with header/x-pipe install. Owners with Longtube headers please come in.
- spark plug removal question
- DIY NPP vacuum help
- Atco Rental October 23rd- Limited Availability
- FAST 90 vs 92
- 2005 C6-Turning over but won't start
- Help Cigar Ligher Fuse
- Coolant temps rise when car off
- DIY brake light socket (harness side) replacement
- Need advice on ls2 engine build
- Best mini starters for blown ls3?
- what do i have to purchase...
- 2nd gear synchro replacement - lots of pics
- blown ls3, what to do now
- Borla touring fit?
- Stroker ls3 cam
- Fob issues
- 2007 convertable trunk adjust
- Clutch
- GMPP LSX 454 Swap
- Hud has no g force reading
- 2005 Shift to Reverse
- Pulling Engine from top off a C6 LS3 A6 // HELP
- C7Z mufflers on a C6Z
- bad synchro??
- Any one run the PCMofNC LS7 Blower cam?
- Silver vs Gold Throttle Body
- Clutch part needed funny story
- Auto-blip
- Who can build me a turnkey 525-550 NA rwhp reliable engine in Central TX?
- Front sidelights as turn signals?
- Squeaking sound from rear of car and seat moves in the car wash help
- z06 spacer and lugnuts... help please?
- Akebono ceramic pads
- Won't fill over 1/2 tank
- How to change TPMS batteries ?
- CNC Ported Cylinder Head Sale
- wiring harness...
- Save BIG on C6 Exhausts! @ MarylandSpeed! (Borla, Corsa, B&B, Magnaflow & More!)
- Trans Temp Too High
- Looking for Tuner in SE FL
- 2007 door lock issue drivers side
- C6 Exhuast question
- Tech 2 reader...which one?
- Airaid CAD intake reviews please
- What are the early signs of clutch going?
- Head swap shop in the Harrisburg PA area
- 2005 ls2 100 hp gain
- 8.7 dynamic compression ratio...n/a ls7...93 octane?
- Calculating intake opening at bottom dead center for dynamic cr
- Service Active Handling - Some questions...
- car not running consistent at drag strip
- ZR1 clutch kit(flywheel, pressure plate and clutch) intalled in a base coupe C6
- Some Handy Free Engine Calculators for You Guys
- t56 tranny and launching
- blinking cel after header/catless x-pipe install
- looking for reviews for c6 short shifter MGW vs hinson shifter?
- 08 c6 oil pressure question?
- Nice B&B Fusion Exhaust note at Buttonwillow!
- Header Debable! Need input.
- Clutch and Install Special @ ISP
- Does this sound right?
- Occasional Fuel Starvation at high load
- need your help on parts...
- C6 Backfiring while accelerating
- JBA headers quick review
- New Hinson Short Throw Shifter Putting In A Little Work On The Track - Video Inside
- Building heads. What components?
- Need a reputable shop in socal
