View Full Version : C6 Tech/Performance
- 2012 + seats in older cars
- Mn6 master/slave cyl., always a problem?
- Engine belts torn on 2005 c6
- LS2 Fuel Line
- Would you buy a supercharger if...
- Transmission question 4L65E HP capabilites
- GTR vs ZO6 vs 1LE
- Hard start some times
- Added Intake - How to check for possible lean condition?
- A6 Tranny
- C6 Pfadt Coilover Review
- best name brand headers
- LS2 using LS7 Flywheel & Clutch?
- camshaft degreeing question (results show retarded 1 degree?)
- Magnetic Ride Control Problem
- Guesstimate on RWHP / Tq for stated mods?
- Exhaust manifold question
- F2 Procharger 4L80E C6 Corvette Build
- Newbie to site in need of help-shifter
- Low beam dead
- Density Altitude Calculator?
- *Free Ship* VMax CNC Spiral Ported Throttle Bodies $150
- stock LS3 heads???
- New member in need of info
- Cat-Back Questions
- LS2 / LS7 Zo6 clutch master cylinder
- Active Handling Recall - GM says go away
- Thought this was trick
- DRLs on C6
- The difference between two cams...
- Wheel/weight Dilemma
- mickey drag radials
- Super charger
- up grade or not
- LS7 Fuel Rails, stock mani
- C6 Looking for a ground trigger for interior LEDs
- NPP/Z06 Mufflers...any way to restrict it from opening?
- Headers?? Anything good for the $$$
- Bullets with b&b headers...yes or no
- Track your car with a cell/smart phone?
- rear outer tie rod boot replacement
- exhaust filler panel for C6 w/NPP
- Curious place for rust
- 2lt to 3lt seat question.
- Exhaust Question
- throttle bodys & intake manifolds for LS3
- Owner
- Headers and Corsa C6 install.
- looking to purchase high mile (97k) 07
- timing chain damper torque/thread lock question
- GForce tune
- Any experience with QA1 coilovers??
- Owner
- Crack in Halltech Intake...Suggestions?
- 102mm and throttle body
- How to level exhaust tips
- performance chips
- Copper washer size
- This budget sound right?
- HELP .. please
- Ncrs-old town in kissimmee florida car show
- Reverse is very difficult
- Got any nite lights
- Saturday nite C6 pics with new seats.
- Very Happy With 1st 1/4 Mile Passes Today . . .
- What parts for tr6060 to 4l60e
- 75W-140 gear oil
- Fast Intake Next Mod or LS3 Upper End?
- Tuning help in Houston
- Ncrs-old town in kissimmee fl. Show
- MGW Shifter
- ITB (Harrop) Inake on my LS2 restomod!
- Ca Smog Legal cam for 09 Z51?
- Open Discussion : Cam & Build Up the LS2, or throw an LS3 top end on the LS2.
- Best Bang for $$ Trick 235/G6X3/FAST 102 or Supercharger?
- Mod progress and problems
- Oil temperature Sensor acting up (VIDEO)
- Halltech Carbon Rear Quarter Panels Ready for shipment
- Texas Speed 1-7/8 header/x pipe package
- GM Aerodynamic Tweaking - read this!
- Huge Airaid Specials Today Only at RDP Motorsport
- Ncrs- old town in florida show
- Okay... Another Exhaust Thread
- What headers to go with.?
- Cleaning LS3 MAF Sensor..
- ZR1 air filter on LS3??
- Halltech GT2 DRED hood in stock ready to ship for................
- *Insider Pics* Pfadt LT Headers, TIG Welding...
- NEW Intune for C6
- HELP WITH FRONT END PROBLEM (Female-not tech savvy)
- Engine Surge or Miss - 3rd & 4th Gear
- Maximizer headers?
- Why are the rocker covers insulated?
- Torque Converter question
- C6 Drag Car Build Differing Advice
- Vararam CAI came in. Kind of worried. Help
- .004 Piston to wall clearance on stock LS3 pistons too much?
- Shift box/detend spring questions.
- Ported Throttle Body PROBLEM!?!?
- Livernois stage 1 L92 cam thoughts
- Best Cold Air Induction Filter System
- Corbeau LG1 seats
- '05-10 TPMS, any way to test?
- Phadt featherlight question?
- Is Performance Exhaust Worth It If You Have NPP?
- Brake Upgrade Advice
- **Header Installation Specials at LG Motorsports**
- LPE GT-19 Cam Smog Legal???
- Car stalling
- >-< St Jude Auction #9 C6 Corvette Body Color Painted Plenum/Intake Manifold Cover
- LS3 MAF install on LS2 need HELP PLEASE!
- Corsa Exhaust - how to tell which?
- Help me pick out a clutch
- GS front brake job tools?
- -LG Motorsports G6X3 package, 100 RWHP gain--
- Zo6 new owner cam and shop recommendations
- HorsePowerAddicts A&A Superchargers Install and sales specials!!
- Z06 exhaust manifolds on LS heads
- RX Performance Catch Can Results...
- XM Radio Module Pic Needed
- Popping sound in tansparent roof
- door control module
- Urgent issues with 2005 Corvette (dealer can't even fix)
- Corvette Forum approved coilovers
- She is BACK!
- seat wiring problem
- Aluminum or steel ls9 clutch in ls2
- Getting my LS3 intake ported
- What will be to most loudest but still classic exhaust system for C6?
- Help identifying this fuel system..
- Need help getting part # C6 seat bracket
- Z51 differences?
- Headers for z06
- 2005 Gear Noise
- 2006 door latch and window not working
- Need help now
- Re-installed the OEM Axle-backs Today
- Want to run .5-.7 seconds quicker in the 1/4 mile?
- Cam packages installed complete!
- How to tell if engine mounts are good?
- balancer wobbling
- Elite Engineering Catch Can
- Using 89 octance fuel in base engine...
- Clutch question
- Torque Tube Issues: Bearings and Snubber
- Power steering rack leak
- TuneTime Introductory Specials
- Advice on Nitto NT05 tires and Detroit rims
- Service Traction System problem
- ls7 warhawk heads
- C6 Exhaust, Induction and Tune
- Quick new brake pad installation question (on '12 GS)
- Battery Voltage
- Best way to make polished wheels shine?
- Stupid LS3 throttle question
- Shift Light
- Diff R & R
- 2008 C6 hydraulic clutch problem
- 08 zo6 fould plug number 1 cylinder
- npp controller retofit
- So What's New
- need your thoughts on brakes
- Could a high speed vibration be caused by a screw in my rear tire?
- jAX Fl coilovers?
- Resealing transmission tail shaft housing with rtv?
- *SALE* FREE Shipping - All Pfadt Products Easy Ordering!
- rust never sleeps
- C5 auto transmission into 2005 auto C6?
- LSX102 top cover fastner torque number
- HELP!! Park Lamps fuse gets blown when I hit a hard Bump!
- Installing Nav in a 2011 w/MP3 port
- 2006 C6 Oil Filter
- DIY PFADT Header Install 13 GS Dry Sump
- C6 Drag Car Build: GS or "Base"?
- Do dry sump LS3s have a 3 bolt cam?
- Standing Mile Question
- DTE Performance Tax Time Sale
- Burnt Distributor Cap
- C6 SC install prices
- Radio frequenti US models
- >*>*> St Jude Auction #7 "Fangs" for C6 <*<*<*<
- ### St Jude Auction #6 Line Loc for C5 or C6 ####
- Any fitment issues swapping a ZR1 trans into aZ06
- Dyno Numbers for 229 236 112 cam though stock manifolds
- New Michelin Pilot Super Sport ZP
- GHL Race Series Discontinued?
- PCM of NC Cam/Heads result on LS2 Vette
- M2W on 2005 C6 with Borla exhaust?
- Ported LS2 throttle body on EBay
- RDP Motorsports New Online Store up and Running
- •► ► EDELBROCK E-FORCE SUPERCHARGER - WINTER SPECIAL @ Corvettes of Westchester ◄ ◄•
- loose speaker wire
- Problem with LG Super Pro slip joints tightening down???
- Textralia Clutch Question
- Need help from the pro's with Stretching ARP Rod Bolts.
- Vbp's holiday sale
- How to replace key FOB battery?
- |||||Halltech Titanium Drag Racing Lug Nuts|||||
- Upgrade to 255s for front tires or leave at 245??
- SIP(stic it performance)/RamAirSS intakes
- not starting
- c6 corvette auto/auto+CAI
- So.Fla. $599~4-Wheel NEW Drilled/Slotted w/Ceramic Pads Brake Install WINTER SPECIAL
- Got my car on a dyno. Pic inside
- 2005 LS2 , Cam, Longtubes, Converter, big gains!
- Sprint Booster
- Dilemma - Which tires do I keep
- Widest Tires and Recommended Wheels for a C6?
- magnetic ride shock replacement question...
- Throw out bearing Tranny or Clutch
- Clock Spring. Anyone know how to put the wire ribbon back in?
- 2005 wanders at speed
- The Best LED Reverse lights Solution from Radioflyer Innovations
- Has anyone mentioned this
- Who is jumping in for the new 7 speed manual?
- Black Cherry Led tails and side markers on RAYZZZ Vette
- C7 Seats
- T56 Trans questions
- Has anybody used these front/rear LED bulbs without resistors and errors?
- A6 transmission removal
- New PB MPH and a discovery
- MAP sensor location
- ZR1 CLUTCH ASSY is that all I need ?
- MOD for a more 'upright' seat back .??
- cutouts/tap into heated seats wire
- What head cam combo to use on 12 gs
- warped rotors
- Kenwood DNX6990HD questions
- Loud Noise when u turn
- Really Loud Slipping noise front tires P275/35ZR18
- Engine Bay
- service AH, and codes B0161 and B0561
- Battery
- worn valves on a stock LS3 motor... what should I replace them with? why the wear?
- Is battery disconnect really necessary for exhaust install??
- DeWitts Annual Sale is on!
- Choosing the correct Race Ramps products
- P0430 code
- Gas tank issue?
- Window indexing question
- Katech Billet Belt Tensioner Sale - 25% OFF!
- Post up your drag set up
- Wideband Bung Location Recomendations
- What cam and head work to do for stock daily driver LS3?
- A6 fluid flow direction
- P0171 and P0174?
- -Another 50+ HP gain with LG SuperPro Headers-
- LS2 daily driver mods (input??)
