View Full Version : C4 Tech/Performance
- Am i using the right torque converter for my mods ??
- Exhaust Tips Take 2
- Suspension Rebuild on 86
- 1985 Corvette Not Starting After...
- Differential Carrier Bearing?
- Air pump eliminator bracket
- Stereo Wire Diagram
- 96 Bose Amp
- Hesitation and blue smoke
- belt to long?
- How much can I shave my heads
- Flywheel Weight - how much
- 88 intermittent no start
- 1985 Engine running rich...
- fitting size for autometer fuel pressure guage
- Installation of Heater Core
- Exhaust bolts
- 3000 for a paint job???
- 1.6 rockers
- best x - pipe to replace resonator, on a 93 lt1?
- best hi-flow cats for a 93 lt1 (zf6) ?
- HVAC drain on battery
- 1988 hood stuck closed
- What are the best injectors for a 87 vette ?
- Boost and Gas milage.. How much / and MPG
- Could this be for real??
- 86 vette tps question
- Fellow Z51's
- brakes
- 96 6speed short throw shifter
- Help!!Advice on strut Rod installation
- Help Need New Vacuum lines
- 1994 corvette need serious help
- Third brake light installation
- Guess what's next
- 1991 tack sticks
- 1994 lt1 asr light..
- Recommend a Cam
- exhaust smell???
- ECM/Eprom changes required for 383?
- What can I get away with
- How much
- Different brake fluid color?
- 1994 Corvette H41 code
- Decision on Intake, FIRST Fuel or TPIS Big Mouh
- TDC and optispark. Help!!!
- Good news for Convertible C4 owners.
- Bad insrument cluster?
- eliminating oil cooler on '87 L98
- 5.7 rod, is there any pro / cons
- 383 engine build, comp help
- corvette with no keys
- Removing Oil Pan on 1993 Corvette
- big time help project
- Rear Transverse spring setup/ 86
- PKE R & R on a 95 coupe
- Dart PRO-1 heads on LT-1
- Valve Seats fall out of head?
- EGR Delete.....
- More progress on the 1996 C4 CE rebuild
- axle half shafts ?
- Are these wheels dymags wheels???what gen
- taking out selective ride control
- LT4 Exhaust on L98 question
- 1984 C4 Air condition questions
- Cam/Distributor gear
- Hawk HPS vs HP Plus on an 85 4+3
- Special type of alignment procedure for Vettes?
- Injector size theory?
- One way to put a dizzy on an LT1
- Who wanted to try a larger plenum on LT1/4's?
- Passenger Side Half Shaft Id Plate?
- Surging idle problem on my 89. Desperate!!
- '84 Belt Tensioner
- Wheel question!!
- How wide are 315/35 17
- '87 stock HEI or is there something better?
- EGR system
- 89 idling problem hheeeelllppp!
- Clicking steering wheel
- R-D Racing Cross-Frame is it of any worth?
- ?'s about removing emmsions
- GM Hot Cam 4 my 94 will it pass CA smog test?
- SYS --flash then 14.0 ?
- How to remove C68 programer on 90 l98 mt
- 96 Lt-4 stopped running on highway and started again
- RetiredSFC97 Thanks
- [new cam]Max valve lift with 113 heads?
- L98 .060 over?????
- convertible PKE remote for coupe?
- You opinion of this new Dynomax no drone muffler.
- Headlight Switch Compatability
- cats or no cats?
- Catalytic converter bolt replacement
- '96 exhaust headers pipe - ss?
- no overdrive @ WOT?is this right?
- I got my 3/8" billet lid for my SR back!
- dana 44 rear w/345s
- c6 wheels
- MSD cap & rotor ?
- Dual Exaust
- Erasing service engine codes
- 84 vette BRAKE FLUSH..?
- How well do 24 lb injectors work in L98's?
- A4 on 94
- 1988 Sport Seat Seat Swap.
- Right Heated O2 Sensor Harness Location?
- Opti and water pump nightmare.. please help
- 86 Rear Wheel Bearing Question
- ECM change vs. New Prom chip
- Driveside Headlight will not open
- Max Speed in Each Gear
- trying to port stock lt1 heads?
- Cats Converter question...
- Corvette Central Dual Exhaust Fitment Issues
- battery drain.
- Who has installed a DELTEQ opti replacement?
- LT1 rods for stroker build.....
- Busted Radiator?
- L98 Monter build 458hp/534TQ
- Horn replacement - whats a good horn
- can the driveshaft u joints be checked to avoid replacement?
- anyone have a link on removing a TB 1986
- LT4 Mods...Next step?
- AC heater unit
- Wideband O2 behavior
- External Transmission Cooler, what do you think?
- Need timing spec for '87
- 15 volts okay on my 94 coupe?
- is it my waterpump?
- Need Help...
- Performance Handling Package
- 93 water pump leaks onto distributor
- 86 cluster in an 85?
- SYS light
- 84 vehicle speed sensor
- Bought Headers ! quick ?
- Rubber under gas cap......
- 96 Options
- DTC 48 (Mass Air flow Sensor Circuit) Slight rough idle, car cuts out. HELP!
- New optispark not working, help asap
- Waterpump question
- ecm plug location
- Stroker Wiseco Pistons!!!!!!
- Tuning issue
- 383 rotating kit.
- BBK Throttle Bodies Experience/Rebuilders
- master cylinder resevoir
- C5 Brake Conversion Brackets
- 383 Supercharged, engine build questions to ask machine shop
- Questions to as machine shop before 383 build
- let play name that part
- calling those who have detonated a stock bottom end under boost:
- Weird "Rocks Rattling in Can" sound?
- Question about TransGo kit...
- 383 stroker LT1....
- Jet Supercharger on CL
- Need help IDing relay
- 87 headlight question
- stuck crank pulley...
- Tech 1 info needed
- 700r4 question
- Transmission Pan Replacements
- Projects using C4 parts
- Aluminum flywheel
- cold start problem
- New Melrose exhaust is here!
- So I bought a new fan motor
- Tranny Speed Sensor Question
- Idle problem fixed (I hope)
- Side glass tracks.
- Bearing washer installation?
- Rr. Brake Pad Change Question
- Intake leaking oil
- 1991 FSM in .pdf ?
- 92 targa on 84 vette ??? LOOK
- What the heck?
- LT fuel trim.......
- 1991 Corvette questions. with pics of my car!
- thread size of lower oil cooler/block inlet
- Optispark difference???????
- Power window repair
- Need help removing balancer hub
- Front licence plate and intercooler
- Many thanks to Paul Rugerri, Seabright, Ch@os, Al Borman and JFB
- 700R4 differences
- Cam tech articles
- Injector spray
- Electric Key Relay
- Almost dying when stopped
- which headers??
- Would Someone Be Willing to Run an Engine Sim For Me?
- Building a L98
- how many 'pistons' are our stock 13" brake calipers?
- 1989 L98, Will these injectors work?
- Shifter knob leather?
- Will 92 top fit on 84 ????
- Recommendations for 88 Vette
- Head Gasket Question
- no spark lt1
- Steering wheel came off!
- Heated outside mirrors.
- Lt1 low voltage. Replaced battery and alterntor
- Engine Temp.
- X Chemical Power Boost - by NX
- Help me choose an opti!!!
- C4 Questions....
- messed up big time...car wont start
- ac control
- ls1 to zf6 how to?
- Head Gasket??
- Would anyone share their tune?
- L83 and L98 heads
- 88 Starting Issues
- Testing Bosch MAF sensor from 87 Vette
- Climate Control - Stuck Buttons
- Idle issue 84 vette??
- Rearend and half shaft position
- New injectors, how to tune?
- Egr install
- Anyone pull a steering wheel lately?
- Best place to place jack stands
- More progress on the 96 CE rebuild - LED lights, and powdercoated suspension parts
- Backup light switch 1995 Manual trans
- Dana 36 pinion preload setup
- corvette side pipes
- Recommendations for Racing Clutch?
- Change Heads and Intake how much horsepower?
- need help with L98 vette!!!
- New chute and heavy duty mount
- Carroll s
- intermitant electrical problem
- dash black out
- Headlight only partially closes
- Help with Alternator/Battery issue and getting to garage
- meth kits vs. procharger intercooler?
- Auto Transmition 3rd gear not working
- HID headlights
- Power Door Lock Conversion
- LT4 head gasket
- Cooling issues
- Hard to start / dies!!
- lookin for a few more ponies - 85 L98
- How much compression is too much, for 93 octane.
- Cam in C4
- Crossfire How to Guide?
- brain dead
- testing fuel pressure on 92 LT1
- what is the switch above the clutch pedal?
- Parking brake shoes interferring with Rotor/drum installation
