View Full Version : C4 Tech/Performance
- Ok, I got the waterpump in my hand...questions
- Will a convertible's x brace help my noodle car?
- Cam Info
- Tranny Cooler Works
- Coincidence- Rear Suspension Damage & Poly Bushing useage?
- Valve train done, just start it up or....?
- What type of grease on headlight motor gears?
- WHAT IS THE "CAGS" DISABLE?
- 85 Power window ribbons...
- 165 to 730 conversion: MAP sensors all same???
- North Shore Motor Works - Chic. area mechanics?
- Radiator cleaning results on a hot C-4 LT1
- About to repalce visor ...how do I get my old one off?
- moving car after tranny removal
- starting problems @ witts end
- Is it the Batt, Alt or What causing this?-Long
- Just found out that the half shaft can make a clicking sound
- Vibrations! new single mass flywheel
- C4 BRAKE FLUID LEAK
- Next Project
- HOUSTON: DYNO DAY REMINDER!!
- headers
- 84 & 85 owners (Borla deal)
- How can you tell if your waterpump is going bad?
- Rear interior rattle
- Fixed the rattle on my Ripper shifter...
- Shocks
- Bad hesitation
- Door Chime Installation
- Has anyone tried carpet dye?
- OBD-II Scan Tool
- steering wheel shakes
- How to fix a rattling side-mirror?
- Important Sway bar Info for 84-87 cars and others..
- If ya got Hookers, I got yet another question...
- Z51 vs Selective Real Time Damping
- 4+3 shifts slow
- brass vs plastic...is it safe to use the brass light...
- picked up Vette today..just a couple of questions.
- L98 Flow #'s
- Sway Bar Bushing Problem...
- Line Lock info .....
- Recommend a mechanic to install Hot Cam in Chicagoland
- my 95 corvette burned up,need info please
- Thanks 18Carfan....
- Cost on a new AC Delco 75-6YR Battery
- Do I need to prelube my Hydraulic Roller Cam?
- LT-4 and Super Ram
- can you by pass a maf ??
- Fixed my 4+3
- Motor goes in soon... Suggestions??
- Fuel injector replacement
- ECM, Timing, Dwell???
- Hatch Strut Replacment - part #s and tips?
- Pulsing Brakes
- How many books for the 96 service manual?
- UPDATE!! Gas vapors & HOT Tank Issue
- 88 Timing Question
- My vette lives!!!!!
- N20 and the TNT kit on an LT1?
- 383 how much hp? need to know
- Super Ram Questions....
- Corsa Cat Back for an 85?????
- Hypertech Stage 2 chip
- FYI Hard Start Problem Symptoms and Solution
- 1996 LT4 for sale 55k miles
- Is there a drain plug for the Torque Converter in the C4?
- Service ABS light
- Paging Scorp Or Anyone With DigiCam..need Help
- TFS 23º Heads on an 85 Corvette
- alarm problems
- How much of a performance increase?
- Join the NCM now and go down in history.
- How can I keep my ECM from slowing me down L98?
- Z-51, Z-52...and so on ?
- Gauges don't match
- Flat top pistons: Which brand to use?
- Crane Cams roller rockers.
- Man it keeps getting worse and worse!! (Better and Better?)
- cams
- Alternator Question
- Spark Plug Wires Needed................
- 3.07's or 3.75's....need input please
- LT1 in limp mode?
- Best place & price to purchase Diacom???
- Anybody Else's Car act like this?
- LT4 Hot Cam
- LT4 vs. LS1
- Rear Tires: 285 or 275
- motor swap progress, few pic's
- 96 LT1 gears or converter????
- Quick Question About My FX-3
- 92 in 1/8 mile???
- One more time! - MAF Screens
- This sound good price on brake rotors/pads?
- Could you post pics of....
- Clearing FX3 Codes??? Service Ride Control Repair
- Differential Lube Change Procedure
- Rebuild? What can I do with less than $3000?
- checking plug wires in the dark
- Redline shockproof gear oil
- Codes 34 and 51, help!!
- Does G44 RPO mean a Dana 44 w/ 3.07 ratio?
- What are the plastic combs for?
- New attennae
- Ever been shocked by your distributor!!
- AFR 190's?
- Torque converter not locking up
- Where is ECM on 88 located?
- faulty clutch?
- I need a performance chip for an 84
- Adding Compression Braking to my Tranny.... Need to drop it?
- ASR Question
- Hey Scrop508!
- failed inspection cause i have no bright lights
- Help! Car won't start
- Left underhood light won't go out
- LT1 engine number location
- Destroyed another AC-Delco Alternator???
- Auto Tap
- L98 stalling when hot
- how hard is it to replace the throttle cable?
- Hard Start Question
- Diagnostic Software Question
- Supercharged LT1?
- Putting a hatch in a 94-96 coupe roof panel.
- '96 Cat Breaking up
- ADJUSTABLE FUEL PRESSURE REGULATOR MADNESS
- New TB, getting check engine light
- Wierd clunk--but not a clunk...
- 1.6 rockers... non-adjustable work with LT1?
- 1st time to the track
- night time driving lights...
- Man, the 383 is FAST!! Even with only 7 Spark Plugs!!
- Hurst ZF shifters are done!
- What size TB on your TPI?
- open header question
- Popping noise in front end
- performance chip
- I have 1990 ZR1 rims...and clear coat is all peeling off bad..what can I do?
- TPI system
- 275 on a stock 16x8½" rim?
- How do I identify a 27 spline 700r4 from a 30 spline?
- Looking for C4 volunteers in San Diego
- Drove on a super rough road, now the car rides worse, and vibrates from the rear!
- 2.59 to 3.54 gear ratio - what are details?
- Someone please help me
- who is using fastchips for LT1?
- Look at service sticker...
- Z51
- Changeing break fluid!
- Problems with ?
- '92 LT1 Cylinder head question............
- drivers side wiper transmission needed for 85 c4
- U-Joint--- What are the problem Symptoms
- Fog Light Aim ?
- who makes the best chips for LT1
- gears or bolt-ons???
- Borla or Flowmaster???
- I am begging for some help now!
- Toasted camshaft...
- Has anyone bought one of the wheel packages from ASF wheels?
- ASR lite??
- What is the disadvantage of running 315/35/17's?
- 89 Vette will not start help needed>>>
- Is it bad to drive at WOT with pinging or rattling?
- Gearing question............
- License Plate Holder on 91+ cars
- brake rotor
- TCC??? What is this???
- Funny acting Torque converter
- water pump
- What will results be if this part is removed.
- Undersize Crank Pulley
- Injector Questions...
- L98 Valve seat load??
- Gas Tank Is Very HOT..so are the fuel lines and etc..anyone have this?
- Outside Mirrior glass is loose
- Otional suspensions on LT1 C4
- Battery Problems. What would cause a new batter to do this?
- IMPORTANT !!! Read C5 perf section!!!
- TB Bypass on 93
- What options to Breathless Vortex Ram Air
- Hard start and running rich solved, BUT I still have pinging
- What is best $500 mod on L83 engine performance?
- All Instrument Panel Lights stay lit up
- Brakes "Creak"
- A/C timer defeat?
- DIY Header Coating
- Oil pressure sending unit location ??
- Need Power Steering Pump Pulley
- the two pulleys on the h20 pump. what's the big one for?
- How to adjust timing on L98?
- VATS Bypass ???
- [NCM] Featured Car: 1966 Daytona Racer
- L98 or LT1
- Yippee, it's out!!
- Can anyone recommend a machanic in the Dallas area
- FOG LAMPS ON AN '86
- Need new windshield - any advice?
- How to replace window switch
- High Pitched Squealing Noise
- Just when you thought you had seen everything
- New batterie
- any problems with leaky headers???
- rear brake pad replacement
- My stroker is runnign a little too hot for me
- Strange..heater core/condensation issue
- Weird electrical problems, need some advice.
- Aluminum Dual Mass Flywheel?
- Paging Patrick96LT4
- Missing 3 RPO Code Definitions...
- Guys, looks like I'm goin away for a while(sold vette)
- ? about mods to '91 TPI.
- Anyone ever break their windshield?
- DexCool vs. Prestone in a '93....
- If you can answer this you are a Corvette Expert
- Incorrect Crank...Two piece What to do....
- How do I begin diagnosis?
- 96 Throttle Body Bypass???
- 86 vette mods
- How's this combo sound for basic mods?
- 1992 stock 12" brakes Vs. Grand Sport. Are the pads the same?
- Is it the blower motor or the relay?
- Unaligned....
- Warning!! - Coolant Mixture and Water Being Used
- 3rd break light
- whats the difference in dia. of underdrive pulleys
- 60 foot times
- Trick Kill switch
- Valve covers???? I need some..
- A/C is toast, think these parts will work?
- Tranny.... un oh... :(
- Polyurethane bushing set help
- best headers???
- 87 cooling fan problem? Thermostat?
- MAF Screen Removal..... how?
- under hood 'ignition on power source,' - 96LT1
- R134a & Smart VOV working great in my 85!
- HELP!! oil pressure gauge problems. someone here must have the answer!
- How to use a fuel pressure gauge?
- A/C Fades.......
- Tire Suggestions Please
- Here's an easy one! Stock fuel line question.
- Any Updates on Hurst ZF shifters?
- Do Computers get Old and Tired?
- Lt1 runnnnning rich help!!!!!!
- Pulling the Pumpkin
- shifter
