View Full Version : C5 Tech
- Bad exhaust valve seal?
- Transmission shake after changing radiator (automatic)
- Can Someone Identify This Exhaust? - Corsa?
- Clicking sound in the steering wheel
- C5 shifter slop
- Bendpak HD9 air line fittings
- ECP radiator leak :(
- Electric seat - which wire?
- Just Purchased C5 - When car is on no Dash Lights and No Headlights.
- 2000 FRC suspension upgrade
- Speed engineering header / second air and rear 02
- *Popped* Dip stick after oil change and hard run
- C5 power seat issue
- Oil change; will front angle of car make a difference?
- Help with oil pressure sender relocation
- Power steering cooler line ?
- 99 C5 - No Comms all modules after trans R&R - have tried everything... halp
- Mufflers only help needed
- Torque Tube Differences
- Spec stage 2 clutch kit - shifting issues
- Car stalls at idle, and the coolant temperature is too high
- C5 Z06 Transmission Removal
- Left front turn signal not working
- 2000 base C5 issue…
- Air Conditioner Issue
- HVAC Problem
- A/C issue. Starts warm and doesn’t blow cold until WOT
- Canned ls1 dies at idle, running rich?
- Tp sensor confusion help me pls!!
- Codes help
- Suspension advice
- c5 only starts if i shake the fuse box underhood hard enough????
- Loss of Power P0300 And P0131
- Intermittent Radio Cutting Out (BOSE)
- Spare key seemed to shut down power!
- Upper column shaft
- 180 thermostat
- 2000 6 speed limp mode?
- Serpentine Belt Squeak Help
- Gauge cluster/IPC Not working.
- Trouble with TPMS Relearn
- C5 corvette dies when slowing down or coming to a stop
- Diff Seal Leak or Vent issue?
- headlights won't pop up or down
- 2001 base corvette auto (rear specs)
- SILVER’S NEOMAX 2-WAY COILOVERS reservoir
- HELP! Leaf spring misaligned
- Anyone do a rear radiator or heat exchanger setup??
- Installed BT module; DIC NO COMM, engine dies
- Stroker engine for road race?
- Oil Dipstick Removal
- 2003 corvette p0300 random misfire nightmare
- C5 MAF Sensor Maintenance / VID
- Seeking heater box seals
- Test for MAF Sensor
- Car starts and then dies.
- trans fluid change c5 1997
- Oil Pressure Sensor Replacement
- Door Speaker Leads
- Tiny MAP sensor housing vacuum hose re-connecting
- C5 Corvette CEL Not Working
- C5 headlight issue
- White Smoke On Deceleration On Dyno
- 1/2 3/4 shift rail tensioner steel pin
- Tapping noise/steering lock
- Hot days only A/C cycles constantly, cool days it's freezing
- Chasing B2860 H
- PVC valve. With LS6. Yes or No ??
- Headlights open and come on by themselves when key is removed
- 2003 C5 brake leak mystery
- Front Coolant cross pipe
- Number 7 cylinder plug problems again
- Question about 243 heads
- Clutch pedal over center problem
- EBCM is applying brakes during normal driving
- Electrical gremlins 1999 C5
- LED Modified Halo tail lights
- C5 wheel help.
- Rear Diff clutch pack replacement
- C5 Headlights Making Grinding Noise
- Oil filter misadventure
- 2001 c5 z06 compression test number??? Good? Bad?
- fuel door actuator
- Coilover kit pricing, worth it?
- Difference in years for c5 z06 shocks?
- For those of you who have installed your own bilstein sports, please set in side
- knock sensor harness ??
- 2000 C5 weird noises happening when trying to start
- Please help me
- Suspension height adjust with 18" square set up
- Break pressure differential switch help please
- Electrical Gremlins, I guess!
- Upper Oil Pan Gasket Weeping
- Passenger door locks using fob, but won't unlock
- ac kit for my 97 base
- Differential counter weight
- Code P4010
- Voltage varying
- Intake manifold from GTO
- Key Fob
- Service Traction Control and ABS C1214 error
- 97 C5 speedo acting up
- BTR CAMSHAFT -LS1/LS2 -N/A STAGE 4 for street usage or replace to BTR Red HOThod
- Auto gear selector busted
- PO336 Crankshaft position sensor Code(replaced it)
- B2253
- Air Vent Blowing Issue
- Running Hot
- Cylinder 1 misfire on 2000 Corvette
- C5 Driver seat rail replacement kit help!
- Help Requested: Strange Engine Behavior following Clutch/Transmission Rebuild
- 2002 C5 Torque Tube Rebuild
- Clutch and Fly wheel Assy Balancing
- Any real world results from Jet-hot header coating?
- 2001 Z06 Metallic Rattiling/Scratch like noise at high RPMs
- C5 Seat Questions
- Rebuilt t56 kicking out of 1st gear
- Seat Slides when braking
- Remote Keyless transmitter
- C7 seat wiring
- C5 Steering Sensor Harness Question
- Repair of a modified LS6 engine that has axial clearance on the crankshaft
- New Plugs
- Low beam headlights
- Z06 pre purchase questions
- fuel level sending unit?
- Turn signal problems
- 2004 z06 p0343
- Looking for replacement fuel pump
- Gear issues
- 2002 Z06 rebuild
- 2nd gear problem
- New radiator suggestions request
- Help! C5 dies when car is warmed up.
- Driver side window inoperable - Help!
- Lost my only key, how can i get the VATS data?
- pushrod length w aftermarket cam?
- 2000 Corvette overheating issues
- 2004 C5 Z06 Low Mile - Would like some opinions on direction of build.
- C5 surge/buck at low rpm on decel... Why?
- Adding a timing chain damper - Template?
- C5 Crank but wont start issue
- Circular swirly noise when car is cold in gear 1-2k rpm
- Gas smell
- Comp BSR Shaft Rocker Experience
- Knock sensor woes
- amazon seats
- DIC voltage vs. Alternator voltage
- Headlight help
- 2nd gear shift delay
- Ideas of things that need replaced P1870
- Valve cover
- Driveline whine in 1-3 - diff or trans?
- Service Vehicle Soon
- are the c5 steering wheel airbags the same all years?
- C5 intermittently starts
- Driver power seat going up on ignition
- What is this tube? Or is it a tube?
- Rfa
- Which adjustable sway bar end links for 1" lowered Z51 c5 w/ c6 GS swaybars?
- Tail Light Covers State of FL
- How hot does it get in the trunk compartment?
- DIC voltage reading & single click when I try to start
- CARB legal LS3 swap
- Tire Size 18/19
- 2004 Convertible Windshield w/heads-up.
- Torque tube shaft won’t fit into clutch help
- Recommendations on Knock Senor Kit
- C5 corvette rear knocking sound
- help testing interior lighting
- 01 with reduced engine power
- Torque tube or transmission issues?
- Power steering pump question
- Going back from Euro Tail lights to stock - what do I need to do?
- 2004 OEM Speedline Z06 wheels vs reproduction C6 Z06 wheels
- Clutch told me no more
- Suspension Questions
- Heater core bypass
- C5 Pulley screech
- Need help with fueling issue
- Front caliper bracket?
- Speed density tune
- Dealing with Lean codes PO171/174
- P1870 from a tire change?
- Parasitic draw
- does not want to start, sometimes
- 2004 C5 Race Ready Questions
- '99 C5 Hissing and droning noises after AC compressor install
- Automatic Dimming Feature on Mirrors
- Quick torque tube question
- Window up/down randomly stops working
- Fuel pump help!
- Re-wire horn
- car won't start, battery boost doesn't seem to help
- Supercharging the C5 Corvette - without blowing your engine! VIDEO
- What Is Your LS7 Preload?
- Sos torque tube wont go in
- Clutch Needed
- C5 FSM full shop manual, someone posted a copy in ZIP?? can't find it.
- Self dimming mirrors
- EGR tube to exhaust manifold gasket?
- Fuel Sender
- Clutch Question
- Service Active Handling Light
- Interior Ambient Temprature Snapped Off
- C5 Vibration at 1K to 1.5K RPM while moving
- Compressor location not optimal
- c5 cooling fan power connector(s) location
- C5 z06 harmonic balancer
- Rockers Identification
- Is this the normal marbles in a can or something more?
- Dead LS1 motor in c5, what are my options to replace it with easily?
- Can’t tell if my balancer is wobbling.
- Z06 Torque tube
- Coolant leak.
- C & S Corvette Lombard bags
- 1999 C5 Intermediate Misfire - HELP
- Stock c-5 exhaust
- Base manual HVAC only blows heat
- Positive Review - Horsepower Research
- Correct Transmission fluid for 04 Z06
- Shutting off after seconds
- C5 Shuts off instantly
- traction control issue at the track
- Car want start
- Vacuum leak
- Steering Codes
- Front DRL and Front Turn signals not working
- PCV Issues
- C5 starts then immediately dies
- Reduced Engine Power Limp Mode
- C5Z Oil Pan Leak (that won't go away...)
- Delco PF46E difference to NAPA Gold 1042 Filters
- How long is a 2004 corvette oil dipstick
- Code 40-3190 or 3091 H C
- Can't reconnect clutch pedal hydraluic line
- LS3 swap
- Swapping out EBCM/BPMV
- Brake Flush issue?
- C5 Corvette Odometer Side Buttons
- C5 Corvette Steering Column Lock
- C5 Corvette Odd Rear View Shifting Behavior
- Broken Radiator Piece?
- Cam
- 2001 need both fans on
- Can Figure Out Cooling Issue
- rear axle 'pinhole' leak, repair or replace options?
- TR6070 + C6Z diff in C5Z Questions
- Hood louvers question
