View Full Version : C5 Tech
- Suspension mods needed to add iron block stroker
- 1998 A4 differential replacement
- Help, stuck rear rotor...
- FLP Long tubes are on!
- Help again! Trying to help a new vette owner.
- Preview: Halltech True Ram Air Power (TRAP) Stage 3 is here
- anyone know what kind of resistor is needed after removing f45 shocks...
- Anybody put stock size tires on 9.5" , 10.5" width rims?
- What is the proper inflation rate for Yokohama's?
- FICHTNER CHEVROLET PARTS SPECIAL.. EXTENDED ONE WEEK 02/27/04
- The unexpected! After retraining my tire sensors.
- wheel speed questions
- clutch adjustment ?
- Chip Alone or Air Intake Exhaust and the Chip?
- Post a pic of the 2001+ MAF sensor..
- Carolina Corvette Challenge interest???
- Busted Exhaust Manifold bolt!
- 416 to the wheels
- Turbo Update
- Can I test my coil packs this way?
- Anticipated ET drop going from Yank 3000 to SS3600?
- TC removal/install question
- 90mm TB is here---
- Speedometer Recalibration
- Signal Flasher location?
- Ground Cable to frame, Where does it go ?
- BBK headers
- flycutting and welding heads-what is it?
- adrenalinrush thank mean green new to web but old with corvette
- Does anyone know? Please help!
- Anyone have service manual on you computer? Need help with clutch!!
- Shifter height
- C-5 manual to automatic conversion
- Which Torque Convertor
- Cut Corsa over-the-axle pipe for alignment???
- oem wheel damaged exactly what components are needed for replacement?
- bolt on Kooks to an LS1 with LS6 heads??????
- Help me decide 390's or 410's
- 18 inch wheels all around--compared to stock
- Adjusting Auto shifter cable?
- 2003 Wheel Sensor Torque Question
- Torque converter question
- Any vendors want to offer info on their big LS6 h/c packages, please?
- Cam and Head install special. Tuning and all !
- ecl relay harness
- 6 speed rebuild how long
- Zo6 rims and tires on regular C5 question??
- Z06 wheels on regular question
- Do ceramic brake pads run hotter than regular..and if so, how much hotter?
- I bought cheap ceramic front pads from Auto Zone... Are ceramic pads pretty much the same?
- just bought a dual cone air filter for 2003 vert and it doesn't fit on mass airflow
- Labor for cam Change? H/C?
- 99 Airbag disable kit install questions
- Atlanta Area - Need cat back exhaust replacement shop
- Cyl #7 Taylor plug wire and TPIS headers
- Oil Filling Cap Loose????
- Which Brake Fluid..........
- [BRAKE UPGRADE] SSBC Tri-Piston direct bolt-in
- EUROPEAN INSTRUMENT CLUCTER
- Looking for A4 tranny removal/install instructions
- 97 A4 w/3.15's looking for TC advice
- Fire wall breach
- How deep, in thousandths, is a 2cc valve relief?
- Service in the Chicago area
- ZO6 rear brake duct install(pre 01)
- How hard is it to upgrade C5 springs?
- HP estimates??
- Doing a Rear Differential swap at home???
- Anybody using the Pro-Matrix from Wilwood?
- 3.42 w/ reprogrammed PCM but still P1571 pops up???
- custom straight exhaust
- Killing myself over Header System (Dynatech SuperMaxx?)
- clutch install write up?
- Ls1 Mass Airflow Sesor
- Belt Squeak problems - need more ideas
- Headers & Gears
- Replacing stock shifter knob on M6
- Cam question
- New Clutch....Help!
- New Products and sales at Speed Demon Motorsports!!!
- Someone with service manual please help.
- Take a look at this site for a c5 on its rear wheels--
- On C5's are all the tire sensors the same?
- Heads only, Very Happy with RPM picked up 38 rwhp!
- Dynatech headers
- Looks like they finally have a real electric supercharger...
- HELP - Check Engine light is ON
- Valve train chatter
- Belt dressing removal
- My thoughts from the Tuner Shootout
- T84/European headlights won't go down - help!
- ******APE's Tom Kempf *******
- Header Bolts - what is everone using?
- clutch life
- vette with no mufflers
- Borla exhaust
- What is the easiest and cheapest way....
- 500 Mile Break-In
- Need info on Cartek and LGM big h/c packages
- super charger
- Gears for Z06
- FAST 90mm TB
- SAE & STD Dyno numbers?
- Will ceramic pads do fine for auto-x?
- Front pads for the track... Carbotech XP-8 or Hawk Blue or PFC 01??
- Replacing negative battery cable?
- How Much Louder Do LT Headers Make Your Car?
- $200,000 vette
- Power Window Controls - Squeak/Rattle
- ATTN: adrenalinrush
- What's a better option for brake bleeding... a power bleeder or speed bleeders?
- Optima Red Top ---> Started Smoking !!!
- SS3600 drivability?
- So where do we get our rotor for cheap?
- Borla Stingers
- My day at the shoot out
- Need Part # for Banjo washers???
- Front swaybar install advice needed
- The ad says "add up yto 13 HP for under $50?
- Norris Motorsports TT runs 10.30
- Where is the Water Drain Plug on the left-side of a LS6 Engine Block - Pictures?
- No Fuel WITH Fuel!!!!
- What RWHP do stock 6 speed C5's usually Dyno out at??
- Who is running Kumho tires on the street?
- Ported and coated oil pumps for sale
- FINALLY IN THE 10's
- ** Major Sprays Vette Doctor C5 9.38 Titan Shootout Video **
- Installed my PIAA 1100x lamps tonight....
- All Northeast Owners Atco Sunday!
- Which Mod First - TI exhaust vs LS6 intake
- Re- Ring job tomorrow in NJ
- OH NOOOO! Locking Lug socket missing??
- bent valve..?
- 90MM FAST manifold test?
- ???LS6 swap with an A4 and 228 @ 50
- [PICS] Look what I have..NEW Agostino 5.3 Stage 2 Heads..a WORK of ART!!
- Halltech's customer makes 400 RWHP (uncorrected) without internal engine mods
- noise @2500 rpm
- LUCAS Oil additive??
- Hotchkiss vs Z06 Swaybars
- update on Finished 231/237 and patriot heads install now?
- My timeslips...
- Help with mods please.
- HUD question. Will be installing once parts come in.
- WANTED TO BUY: Used Corvette Differentials.....
- 10's on F1's
- Anyone use this SLP cam yet?
- ACK!! Oil Pressure pegged out on high side!!
- 3.42 REAR INSTALLED IN MY A4 AND NOW I HAVE NOISE AT FULL LOCK
- Brake pad & Caliper
- February Vortech sale ending soon!
- DeWitts New Site!
- ASP underdrive pulley ?
- Steering Column locking recall and PCM flash?
- DRM RADIATOR E.O.C. SYSTEM GROUP PURCHASE C4 & C5
- milled LS1 heads, how big can I go with cam?
- I KNOW this has been discussed a zillion times but I need a clutch and
- turning fidenza flywheel?
- stroker info--can't find the eagle thread
- Kooks Headers????
- Stress crack in wheel..Where can I get a new polished wheel for my Y2K car?
- Anyone convert 97-2000 MAF to 2001+ MAF?
- Tuner Needed
- ****Thanks Cartek & all who came****
- Noobie question.
- Arizona conditions and VR-1B
- Vibration under high speed (160mph-120mph) braking
- The best tire for the performance driving and street race!!!
- BRAKES BRAKES BRAKES!!!
- Is it possible to buy the retainer cup on the shifter seperately?
- C6 rotors on a C5?
- J-Rod VS Brent EB02
- Looking for FLP Headers, Best price?
- Warning - HAWK HP plus pads!!
- stock shifter with Hurst short throw??
- G5X2 cam help....
- Simply Shut Down While Doing 65 - 70
- How hard is it to remove A4 trans from a C5
- Electrical Problem
- Best Launches
- Need Info on the Evans water pump!
- Why is my car sluggish off the line at 70 degrees & above?
- Thanks to all the Saturday "BRACKET RACERS"
- My car shootout results.....no worries in here
- Question for those with 345's on the rear
- Special thanks to our tuners--
- can i add the delco cd changer to my 98 coupe?
- A&A shortblocks
- Tires
- Drag brakes for a C5?
- Oil level question
- bilstein shock number?
- Knocking Sound At Start Up
- best tires for ride, noise and handling ?????
- Poly/Rubber bushing combo results
- What a surprise as I return from Iraq (thanks forum vendors)
- Just a few pics from SC
- what kind of power?
- Gears & Headers
- Had 2nd fastest car this weekend
- Going from LS1 intake to LS6?
- 10.3 @ 138 mph LPE TT pump gas low boost/Tuner shoot out
- Heads/ Cam!..Twin Turbos!..Superchargers!...Nitrous!..TUNE R SHOOTOUT a bonanza of C5 technology.
- BIG Thanks to Cartek
- M12 tranny + 3.15 gears? just a quick question or two
- Titan Results
- All Magnuson superchargers on sale!
- An OBJECTIVE view of the PERFORMANCE SPECTACULAR TUNER SHOOTOUT!
- 10% off all Yank torque converters!
- NEED HELP! Internal engine tapping! (Long Description)
- Of all the fluids my C5 could run low on...
- Question about setting Lash
- Yank TT2800 LS1 Torque Converter
- Anybody try this cam?
- C4 rims on a C5
- Which is the better shifter: B & M or the Hurst???
- Big thanks to all the participants of The Clash Of The Titans
- My Cartek Shootout Results
- Good Shop In Orlando?
- Maybe upgrading to 18 and 19 inch rims...info and pics please!
- ABS Is coming off, can a dealer remove all of the stupid codes?
- My Shootout Results
- Idle problem-help
- Hey you guys w/ rollbars! Thinking about a 4pt, where and how much?
- Help!!! Error code...
- Tire Pressure Sensors
- So what are the results from the other classes of the shootout?
- Cam Info needed again.....
- PCV mod completed
- HELP, '98 won't start.... p1518 and p0601
- 16" rims, pics of control arms?
- New C5 owner questions
- zo6 shocks?
- Knock retard on a 04 Zo6...can it be fixed? What is it?
- fuel octane?
- Any FAST LSX Intake results with bolt-ons or cam only yet?
- New Spec II clutch wont fully disengage?
- removing the catalytic convertor?
- 3.73's factory option?
- 12.79 @ 110.03
- HELP LS1 gurus! Miss or hesitation at WOT!!!!!
- ANYONE WITH LS1 EDIT AS THEIR ONLY MOD ON C5?
- PART IDLER PULLY MOUNTS TO BROKE OFF
- Air bridge Question??
- car running hot need help
- HYPERTECH POWER PROGRAMMER 3???
- Testing coil packs with inductive timing light
- NOS SYSTEM!!!
- ACTIVE HANDLING!!!
- GM, Microsoft and the C5 Tech Forum
