View Full Version : C5 Tech
- How do I increase my fuel pressure on my 04Z?
- Electric Water Pump
- I'm gettin good at dropping the drivetrain...
- Reverse noise
- Leather Seat Care
- What went wrong with my transmission?
- Throw out bearing rattle on takeoff?
- i need help how to install a fuel pump!!!!!
- A/C Problem!!!!! Help!!!!!
- Starter Problem
- LT header dyno result?
- I need a new top
- abs pump advice needed
- Repl turn signal socket repl - help!!!!
- Dropped a key inside battery tray.... help!!!
- Tie Joints Rear on C5/Z, melting
- Could the Driveshaft Shop cure our wheel-hop woes?
- window won't go down
- Codes!!!!!!!!!!:(
- Replacing relay in engine bay (where fuses go)
- Remote fob problem. Please, please help! : )
- Fuel Pump Sending Unit Wiring Questions (Inside Tank)
- Change out brake Caliper procedure?
- Smog pump bad?
- [HELP] Drivetrain removal on a '97
- Whistle after shutdown of supercharged LS1
- **2000 C5 Corvette 63rwhp gain with LG Street Series and G5XE cam**
- thermostat on engine inlet...why?
- 505a's What size?????
- Cam on stock A4 ?
- water around door
- Ques.. on mounting Pfadt Coilo.. on C5 Z
- LS3 or LS7 from a LS1 & Knock Sensors - What Cal Change or Conversion?
- M6 to A4 - differential swap?
- Cruise Control
- Help with an Alternator!
- oil catch can question
- 97' with Analog Climate Control to Dual????
- Any way to tell if a used differential is good BEFORE installing it?
- LS1 blocks question
- Brakes locking up
- Windsheild Wiper Arm Help.......
- are C5Z and C6Z engine cradles interchangeable?
- Door panel advice needed
- How to : Reset " Service vehicle soon" message
- Problem resetting Oil life left monitor..
- Help!!!!!service streering column, pull key hell!!!
- where do knock sensors go on LS3
- sensors next to starter.
- Which is C2 connection on PCM???
- LSx V8 RX8 Coming Soon!
- stock injectors to 55lb, what can i expect?
- Bellhousing dowels
- What causes corrosion buildup behind PCM?
- could use some electrical help...power distribution
- Need Tech Help Plz......
- High Voltage/Charge System Fault
- Interior light dimmer not working
- Differential Replacement 2001 6 speed
- New motor wont turn over when Hot???
- ** Im trying to hook up my iPod ***
- Right front tire going flat?
- Drives side seat....
- Virginia Speed...Holiday engine sale!!!!
- Bad Wheel bearing???
- What is the highest gearing for my 99 A4?
- Has anybody ported their own heads?
- Odd Tracking at Full Right or Left Lock...
- Abs/tc/ah
- What is the next step
- Looking for shock mount/shock installation pics
- Breaking the tires loose on an ATX?
- belt squeal
- Active Handling
- Black Box Mounted in front of PCM...
- Need help!!!
- Issues With Disconnecting Battery
- Capricious HUD
- replacing header gasket
- Oil leak treatment?
- Noisy Fan
- LSX-LS7 heads and intakes are here at SDPC!!!
- Another CAM Thread
- fuel leak
- Rear end lube
- Passanger side headlight motor repair
- odometer problem?
- Changing the stock head unit,how bad is it?
- Even Deeper Discounts on Certain In Stock Short-Blocks @ TSP!
- new pads old rotors?
- is Agostino Racing Engines of Canada still in business?
- who is the man for MAIL ORDER TUNING???
- timing tuner install ?
- •► ► AMERICAN RACING HEADERS - ON SALE @ CoW ◄ ◄•
- Brake Master Cylinder rebuild?
- •••> CHUCK CoW's HOLIDAY MAIL ORDER TUNING - THE BEST DEAL AROUND <•••
- Mil Yellow Magic
- Parameters for RC 71lb injectors
- upgrading engine parts need opinons or other options
- Front brake duct fit problem? Screen falls out!
- Injector cleaning
- Question about serpentine belt...
- New 04 C5 owner looking for some input
- column lock question
- Upgrading to 01+ Key fob TPS on 99 newer car
- Sil-Glyde lubricant
- LS1 Waterpump
- fuel pump/filter help PLEASE!
- Vararam Power Duct
- C6 oilpan
- charging system
- *Huge Sale-B&B Exh/AR Headers/HPTuners/EFILive/APR Carbon/Cams*
- Need Help! air-intake on TB
- Removing Catbacks with
- Diff whine
- USA tires
- Need opinions on heads cam and spray setup
- A/C Motor noise
- Go with 3.42 vs 315 rear end on a 900RWHP, pls advise!!
- Issues with anti-theft and HUD
- **10% off all Corsa Products through New Years from LG Motorsports**
- Ccw classic wheels
- Need help with LS3 install
- Crank shaft sensor ??
- EnglandGreen Mayhem II cam only - 435rwhp - Mojo1
- Weird light problem.. I think it might be electrical? Check this out..
- Ported throttle body sale, Camaro/Firebird/GTO & C5
- Any transmission experts please
- Rebuilding Wiring Harness Plugs? Anybody?
- Help P0132 and P0155 codes
- A Note on VHT Caliper Paint..
- ** Hawk Brake Pad Super Sale **
- Reduced engine Power Code
- No Brake/Signal/Hazzard Lights
- Ready to buy - a few questions first.
- Slight whining noise from rear under light load.
- A good combination !!
- Questions about catback-to-midpipe connection
- Is an alignment needed????
- Transmission paint
- Z06 TCS-c1214 and front suspension problems.
- Read my plugs plz
- Hatch removal
- Anyone use the Volant dual cone air intake?
- Good morning help!
- Do I need a larger MAF?
- More Mods due next week
- New rims and tires installed today and my TPS needs calibrating
- Changing Wagon Wheels to Thin Spokes - What do I need ?
- LS6 Heads Flow Numbers
- Window Height in Middle...
- Active Handling Warming Up
- Me again....T.B.????
- My first caliper rebuild and paint
- Help!! DIC buttons not responsive
- IAT sensor replacement
- Possible slave cylinder problem
- LG 3 Inch vs. B&B Bullets
- I need help with my next upgrade
- Factory Air Intake installaton help
- 2003 Z06 engine components
- Radio Surround Gap
- Idler pully noise 2000 c 5
- How much does the diff weigh?
- Tell Me About 317 Heads
- C5 versus C4 brake booster
- a/c drain line clean out
- Electrical tapping noise from both ends of car
- Header Gasket Install...
- Check engine light = no code
- turn signal bulb
- 97 C5 shock problems
- Paintjob chipping
- Error code P0155
- FINALLY!! T2 Widebody using your stock size wheels!! {pics inside}
- mill heads? intake & pushrod fitment
- Dyno ?? AFR Pegged at 4.2K Every Run
- wideband-sensor.. where may i put it
- Best DIY differential swap thread!!!
- VATS-Doing something wrong
- 6 speed won't start
- Door locks
- 1998 C5 Mystery Knock
- Anyone have their throw out bearing weld to prop shaft?
- Camshaft end-play?
- Nitto Invo's, anyone have them or recommend them ?
- Time for new tires?
- Seeking info on building my own Coilovers
- 00' C5 automatic transmission acting up help please
- Door panel red reflector, pull from the bottom ONLY
- Stock 2004 model want to add 50 HP
- Faulty gas gauge
- Custom cam vs Off the shelf
- Anyone ever done the Washer Mod?
- advantage of c6 shifter
- Rear end clunk!!! Help quick
- Need some help!
- Post Your Dyno sheet N.A
- ques. if someone could help real quick
- COMP Rocker Trunion Install
- Fenders,,,,,,aftermarket, 1/3 of the price of GM, do they fit???
- Speedometer shows 15mph when I'm not moving
- can i use c6 z06 headers on c5??
- Need rough idea where I stand with HP and my current mods
- Can I drive without the AC belt on?
- Another HVAC problem! HELP!
- Left Leaning
- Visors are different.......? zo6 vs. coupe???
- Service Traction Service ABS Light
- How can I troubleshoot my climate control system?
- <<<<>GM DISCONTINUED parts list---C5 hud bezel, FRC roof trim, DOORS????
- Grinding noise from rear..
- OK new valve springs......now what?
- Loose Bezel around starter ****ch -How to Fix?
- Anybody that just bought the Vararam VR-B2
- •► ► CHUCK CoW - BOOKED in ORLANDO this THURS 10th - SUN 13th ◄ ◄•
- Remote Key Fob Sending Double Commands?
- TPS install question
- Just curious?
- FOB Retraining or Tire retraining
- Is it ok to jump start a corvette?
- Does anyone know what this is???
- Sylvania Ultra headlights
- Drivers Front Turn signal not working
- **LG Motorsports Dyno Tune Special $399**
- Why swap o2 sensors
- Is it the relay or headlight motor?
- MILITARY MEMBER STATION OVERSEES NEEDS HELP seems like the fuel is being cutoff.
- 2 Step Questions
- Can a bad REAR O2 sensor cause decreased gas mileage?
- Tire ? 315/30/19
- good cam for "cam only" car
- Best Clutch?
- Centerforce Dual Friction install question
- Cam longevity question
- Trickle charger help please...
- Tick MC - Any Regrets
- Cant decide on which heads to use...help
- Can someone tell me what battery to buy
- Air intake cleaning suggestions???
- Magnaflow 16732 Vs 15713
- Defeating the TPM
- paint
- I need help with Wheel knowledge..
- Noisy headlight
- weird metal on metal sound when I hit bumps
- Ticking sound and service engine light
- high mile 98 vette
- ABSFixer review
